Im replacing the whole thing and i dont know where to get a new one i just found out 5 mins ago that the one u ordered isnt in stock and its not coming after all it was an ACDELCO part number 252-542 if you have any other places where i can get one at a decent price please let me know and thank you again for all your help.Are you replacing the entire housing or just the pump?
The housing is casting is durable, but fragile. Be sure bolts go in smoothly and only torque to the right specs otherwise you may crack them.
Use some **** or assembly grease to keep the O-rings on while assembing.
You are going to use an 11mm or 10mm for all the bolts, but you may want to remove the battery box and air box and intake tube to get room to work.
Your hoses are all going to stick good to the aluminum housing so getting those off will require skill and patience. Use a hose tool (or long needle nose pliers) and twist at them to get them loose.
If hoses are original, do yourself a favor and replace as many as you can. They may fail soon after the fix.
I ordered it from ebay of all places lol and the sent me an acdelco water pump worth 54.00 and not the 275.00 doller entire housing i paid for.I don't know where you ordered from.
I looked up the pump on Rockauto.com. Your AC Delco number matches one of the pump options they offer.
In the info for the pump, they offer an alternate/OEM number of 12494291.
A Google search of that pump number comes up with pictures of the impeller and pulley assembly only, compared to the entire pump assembly as pictured on the Rockauto website.
Clear as mud?
