Jordan's Rebuild Plan of action
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
I thought you guys had the squirrel catcher that is found on the XSport too. Hmm, didn't know you guys didn't have it. It diverts air up to the PTU and rear catalyst. Wonder how hard it would be to fit onto a SHO...if someone was so inclined.
y4mf253wgH8wTybtAHVNSi6CuHipWq4cTNx9PEP7UcAPPAVc3Ic_I-KTUWTEzOQUjjDZejOVFo3Dlbz8ZgFp1G-ceipU60rLn1TXpQNFw3IaCaXud8L6y0J6VR8Y0QRbTcrZqT_K18gtMo_KxEoheXFVCHQzW2-1lWfRwSkEdXr7TkaOteWocHhPtSt_VtAZdzC148cHej86fRUGsgoDojDgQ
y4mjfkLwmD47DIXnbDWjhjkj_-4sEtAymWr0c4mRR71wHrthdAz3eSorZoTm5_pijxMvsk2W_P3lXkER6lMSqpTVzlsQJ516zjJinKHC6PBLm_0KTHl2JALZBQlIoXtDSsgETnodJYiCrOwj3ImMiN2qkHlD88D4s3T9DIaGXXXVLecRe2kP6ikXpFGVq10bzj1zafvEq9yxM0X6JEGGSqrsA
y4mbkV9tE0iKV8WrXx-NF3AXdMgBqOw3toiMjpqSgQkevGbPfaCB8Rh1okZD_JGrGRk74DezCm6TuC84Tb634B2C6bNtv7b7OihjtWHFaw0g63G5ZcRGeMcHrcyDE3QSVGmXxXUTJJb9C37sng9Bt6MJ3vI8pZ6utZP0Av-QdKnWxkL5krAzyZf0i5-01wMsAAsejU2D8pvxRQpZZFGZF_LMg
y4mMOFJ8ZgpmjHI3gJuQqTRA2sPrI1bsmDe1CpbjfUGndmkMMPyfsKChfqFKUMiv2kaimYg8z3GMDAe8NfEYGZrx3Oo0WUR8D91LbYUTeCr2Od2Iemub2vr8FDzfJ69A5ba_gmY6nJG6LQjHiwyVjuSvoZq27Dxt--Y3D-xGcZpTwBrx5OrwqAK0U7Dhm9lxfvoZ-1n_C7xjcqU55EK03r6_g
y4m-FiNIovgy2aQTDC3nJXUKwyiFM8GVVY7YH9XnpUL9KLE9FTDl2Dg4elJx-yWqvqn8iKzryp3M7kQMYuQyfUd_TyHLv8VzHUyRFliNlNEc6eZOO315J7LeIVxwkHBs9_f7cO8IJUrjFJ3jFBuKuJ42IrewV3Y_QRBPs3jnUB_VQVSJb2bylg1im4Q6AGk_UOKrts9jcM9zSp-zXolYeiglw
I been toying around with some carboard cutout to see if it's possible to make a larger one out of aluminum..but it's still in the cardboard stage LOL...
y4mZt0JLvL4tMv7vxZ1VUUiCrkxnbTI92XT3ruzxRdIsCFSN76iEEe0-7Uzu1-KVq9KsWd60t6bEPzoREXjRD0exuYbGSzLDL1qfB0Q20e094f0p2JssftIRFuFXBQGRuDTMD0eMCgmIaj31rb4fZsTr-XiTRyC2hqBlF5LPHmCcm1Uio6f26du3sMpjrvSwc8ya8J46rVK3MDE5CQ5oDWhMw
y4m2IeBewUrkM1UMkWuOBwPRIkWfY6ZZsXUI5onA0Aj8AmGJGM265FFyJEp9aoZ4ZQ429MvIaHrhZDT0NITqGkPJT8Dhx1UcPnlUxQYipvIihdjKdtqz6BeQ62qdzTparpHTr-YVNmd4RoEtqprjY_TR2c2MssvNbf8XXVMkgMb_bd1MLKswCfyu4dDtPYxnkGV87bsBAyzR3e8AJzZn59W7g
y4mUN7W2-7denHOwss0Jzqrd3OQTaoIqomwzcaK_QHjMsOZojv2i9rVcFvhULJ-ymO9t9Kj9lgMfuN7yZAZfv83Xpq_yJO_p_-iYZhu5Q3zZzTtoWCAC4U9-g27GnyuBFLgfuMrHwFPMwmsKyL26kJM2SF4YtLIwt9h3-JgYs4cuq1sX6xaY_OWoyUU2wqyfwPih4EQxZqVj-fApH2q9uM-sg
The Flex model has this integrated into the belly pan, though I do like how yours is more of a ram air effect.
xartic1
Colorado
Explorer as well. Mine was missing when I purchased my Sport. I recommend using any bolts other than the ones it came with as they have about a half a turn to tighten them. Otherwise you probably will run over it when it falls off.
DB5Z9910494A is the part number.
Ecoboost_xsport
Sacramento, CA
Yeah, we already clarified that the XSport has it a few posts up...and I wouldn't recommend changing out the half turn actually, it shouldn't fall off unless it wasn't tightened properly...
xartic1
Colorado
Yeah, we already clarified that the XSport has it a few posts up...and I wouldn't recommend changing out the half turn actually, I shouldn't fall off unless it wasn't tightened properly...
Tapatalk didn’t load all your pictures for me so I didn’t see where the part number was listed.
I ordered some extra clips since mine was missing the clip in the back. The first one turned up front made the clip in the k member come out so my confidence with those were pretty low. Makes me wonder if the even sold me the correct ones.
I used U clips with M8 bolts that I feel more confident with them hold with blue loctite.
Jordan_R
Missouri
Been slow. Ordered AN fittings for the trans cooler set up and port matching has begin. Turbos look spicy and pretty decently sized when compared to the OEM ones. That's about it.
Machine shop walking through molasses. Crank balancing machine broke so their estimating they'll have it replaced in a month. 2021 it is at this rate lol.
Ecoboost_xsport
Sacramento, CA
What turbos you go with? Or is that top secret? Lol
Jordan_R
Missouri
Just out of curiosity, I'd be interested in seeing your spec sheet. The injectors I got are from his first generation injectors, so I'd love to see if improvements were made...
Sent from my SM-G965U1 using Tapatalk
I honestly haven't even opened it up. When I do I'll post it!
FiveLeeter918
Tulsa, OK
Uwe told me the new ones are +50% today, what cc are your Gen 1s?
313tiger
