Deatschwerks DW300C Fuel Pump
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Hey guys, wanted to update on something I've been working on with Brandon and Mark from Deatschwerks. A few months ago, I started hearing word of an LPFP in the works for the 10-19 Taurus SHO. Many of you know I run the XDI35 HPFP with stock remaining system on E74, and start seeing fuel starvation issues up in the top of the powerband. Since I have worked with Mark in the past, I reached out to him regarding the pump, and he put me in touch with Brandon at R&D.
I know of a few people running the DW300C on the 10-12 cars and it is advertised as a drop in unit, but I couldn't find much data for the 13+ cars, so we used @Jordan_R as a guinea pig to see how the pump worked. The pump had horrible fitment issues, the electrical connector was completely different, and Jordan ended up actually breaking the discharge snout on the pump trying to get it together.
A quick call up to Brandon found that there are actual physical differences between the two pump modules, so I bought an OEM 2013+ fuel pump module and sent it with them. They've had the module for about a week now, and called today to let me know they've modified the kit to be 13+ SHO Specific and it will be drop in, but will require splicing of the electrical connector since as far as we can tell the OE fuel pump electrical connector is proprietary, as my Ford rep and I spent close to 2 hours in the Motorcraft connector pigtail catalog trying to find a match.
They are pulling it back apart to develop an install guide, and then they plan to get flow data before sending it back to me.
All-in-all, I'm excited to bring this to market, and will be adding it to our site for purchase as soon as we get it back.
FiveLeeter918
Tulsa, OK
They need to communicate better over there.... Here's the pump flow on my 16. Look at the date.
Chris was let go at the beginning of July, so there is a chance that nothing was ever finalized or documented. According to Brandon, the only one they've ever done in house was for Randy Baird, and that is the system the previously labeled 10-17 Kit was developed from.
Johnbigdog
michigain
Really random, not really sure where to bring it up. Here seems good.
The 3.0L in the Continental and MKZ (I believe these two are the same from memory) has one fuel pump module, but two fuel pumps and 2 driver modules.
I dont know if they can be modified for the SHO.
MHW100
British Columbia
I don't have a consistent supply of E85 but would like to push the car a bit harder.
Does adding the LPFP allow more power to be achieved on gas?
My mechanic isn't comfortable modding the pump housing. Is there any service provider that does it so its plug and play?
FiveLeeter918
Tulsa, OK
Deatschwerks will do it for you but you'll need to call them for a direct quote.
The stock in tank pump outflows the demand for the hpfp so not sure youll see a difference.
StealBlueSho
NA
It’s really for longevity... although the only person I have heard burn one out was Rich... and he was running E85 with an LMS experimental tune.
MHW100
British Columbia
Can the LPFP be tuned or is there some other parameter that is adjusted?
MHW100
British Columbia
Trying to order a complete assembly but keep getting conflicting part numbers. Could someone please confirm the correct on for a 2018 ? Thank you.
Michigan-SHO
Michigan
it will run perfectly fine as installed and driven by the factory tune, but you can increase pump voltage to get more flow.
I am NOT A TUNER so this question may be dumb but,
by increasing voltage, thus increasing draw on the battery, would this require a larger battery to handle it?
Ecoboost_xsport
Sacramento, CA
You wouldn't be increasing it by that much, or at least shouldn't be. Although I'm curious as how you would accomplish this. These pumps are PWM, being controlled by a fuel pump control module, not the traditional relay driven fuel pumps...It is that FPCM that may or may not be able handle any additional current. I haven't seen anyone really tax the factory system in our platform yet.
