ATP Turbo upgrade help
I assume you’re referring to choke region operation where temperature skyrockets and density drops? Yeah rarefied works.
But since you used a word I didn't know... I'm going to take that as disrespect. Watch your mouth, and help me with my wastegate spring!
You sir have won the Internet today. Lol.
Did they obliterate any ATP markings while they were at it, and then emblazone them with their own horse $h!t logo???
So lame.
Speaking of horse shit logos...think a grinder will work?
Ecoboost_xsport
Sacramento, CA
Lee said it isn't looking like a boost leak in the logs. You are probably in the same boat that I am. Brad says my turbos are probably worn out. They just dont make the sustained boost over the rpm that new ones do. Add the altitude in, and that is probably the bulk of your issue.
Wondering if this may be caused by the cracks that ATP found in my stock compressor housing side of both turbos when I upgraded to the ATPs after sending the cores back. These had only about 29k miles on them.
Could be the cause of an unidentified and irregular boost leak.
They said to me (unverifiable and exact numbers weren't provided) that they see this A LOT on the OEM ecoboost turbos they get as cores.
Ecoboost_xsport
Sacramento, CA
Alright boys, I got about twenty more minutes of shit posting time before I'm home and relaxing and not getting paid to meme. So if you have anything now is the time.
Man, it's 1030 PM (2230hrs for all the other mil/vets here, lol) here and I am just NOW seeing this hot-steaming-turd-pile-dumpster-fire of a thread and I didn't get to get in on ANY of the action...I'm so sad right now.
High on Ethanol
Just Ain't Care
USA
Where the **** were you? We were all banging keyboards at work to pass the time.
stripSHO
Idiot Savant
Detroit
Stock at 7psi sounds about right. I'm almost certain that's what the truck has too. What's got me concerned is I started seeing a limiter called cylinder pressure. I'm scared to adjust that one.... im at 24psi boost.
If stock is 7 psi, why does turbosmart have a 7 psi "upgrade"?
4 psi has been tossed out a few times over at EBPF.
Also, here's 3.19 psi in the ECU:
Upload 2020 7 10 6 8 4
Also, here's part-load data not-so-coincidentally showing 3.19 psi @ 23% wgdc:
Upload 2020 7 10 6 11 50
Regarding IMEP, if everyone abided by that limit there wouldn't be a SHO with more than 375 ft-lbs of torque to the wheels. Best to look around and see what others are doing with the f150 to get an idea of where to stop
High on Ethanol
Just Ain't Care
USA
20200710 070934
High on Ethanol
Just Ain't Care
USA
Ha! Newbs... I have a "Government Job" but I work 0700-1900 Hrs Tue-Sat but those 20 hrs of overtime at over $30/hr is whats gonna pay for my go fast parts. :boink:
You work for the Somalia government? That rate seems low even before overtime. I'm non government and non-union at 50/hr non-overtime. When we do government work it goes up in the 60s
Lincoln Ne
Government of Nebraska... I'm a Correctional Officer, our union worked hard to get us that pay lol
High on Ethanol
Just Ain't Care
USA
Ah ok, when people say government i always think the federales. Thats actually real good for that then. I think the rate my friend Travis gets is around 21/hr as CO
crystizel
