All you need to know about catch cans.
GotGrip?
Conversation Ruiner
I thought there was a thread on here about not being able to use the dual cans on the 13+ SHO's due to a sensor on the front pcv system.
Ryan Selcer
Colorado
I thought there was a tread on here about not being able to use the dual cans on the 13+ SHO's due to a sensor on the front pcv system.
That is correct, I was reading that you have to have your tuner deal with it by shutting off that sensor or ignoring it or something
Hmmm, weird. I have the UPR catch can setup as well and I thought I bought it with all the bells and whistle, but mine connects differently, per their instructions. My clean side is identical (IM to drivers side port on CC), dirty side is identical (rear PCV to top of CC), but the WOT side is different. I had to tap port I had to make right after the air filter (I tapped underneath the tube of the AirAid filter) a connection they gave me that goes from there to the passenger side of the CC.
y4mK59pzrB-azqFKjrcAfvOlO-zDCLNwz_Oj1F9mRdT2Xx5sBikX2YIj-1dynVb0OsOMAvxxPfPZ7eRuubphAUeGDhpl106oTJnIuSVrx560nqVWq8j4Ox7yE28YwkklI39n8ZMFvM2oI7jQlEW1B7FyTcQk1gD0vTr1RDjhS0A9D5R_z1TSO-SN_QfAnxg3OF47yec-_yUWj0slcAvxXOwUw
y4mfO81WKnMh5IB_DiD0gkAagFfj64F40JcNE0Qg9S15YI6lhvgJ6EA1Uobn0emhNY9nOhICcpRy-uDpBuR85vqm4zUudyU5lgDljm2dPBuZD2S4t_QtHIiw96X-uhnoMmzNaLrnukraTFVhskKBnYcGFGNEKQfoinhLjAqX-Q8j-45w11bYdycb0Qoqav151nMZNsv3HhNF7KcWzqMR6DO_w
But I still have the OEM front PCV line that goes to the connection new the front OEM BOV port as well as the OEM oil cap.
y4m3Alya70MhQPSg-2y9vYnGHYn-Kwru32MCW-rzg8gkKVUwvyFppdOnyVZ_bgHJA1jrdSDfnD8kqmJz90eQQGxDyQnyAQYnO1e7aCp7EuU3eKQHFlcFSc9wh7QX1EQX6GZc1VqYzAno4NpDDZyFKVvd8aGhNjdSkI2jV__DnuPwnd1NEuuz1banqWpxIRyFC3bqXScLoFZ9aLKku_19a-hSw
Am I missing something? Do I not have the "dual valve" version?
You don't have the CSS. Also you had to tap your intake tube because it is aftermarket.
I didn't have too. I literally plugged and played it. No tuner modification needed. It was my 2nd mod. I didnt tune my car for another 3 months after.
GotGrip?
Conversation Ruiner
Looking at their webside, it says the UPR only works for 10-14, guess they must have added that sensor later.
Ecoboost_xsport
Sacramento, CA
Yeah they originally sent this large 5 or 6" diameter silicon section that had that connector in it. After I called them they said since I had aftermarket, Id just have to take out the connector and find a way to make it work. So I did, LOL.
But as far as the CSS is concerned, you think I need it? They don't advertise the CSS for my model so I'm wondering if there is some issue with having it on my application
I dont see why it would be an issue.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
the 15+ kit is different because of the pcv flow sensor, you can't just remove it for the 10-14 kit. We do offer tuning to remove that sensor via the tune if you want to run the CSS, but otherwise it just goes into the port on the intake.
This is what the extra bung option is for on the EPP intakes. if you have a 15+ and the EPP intake there is nowhere to tap that fitting to, so Mike offers it as an add on.
The more I read the more I believe the 2013 was the best year for the SHO...
V6fan
MI
Since I’m also contemplating a CC, it’d be great if others could post about non-UPR choices.
I’ve seen a few others in multiple other posts talk about ebay/other CCs adapted.
FiveLeeter918
Tulsa, OK
half the price, half the protection honestly...
GotGrip?
Conversation Ruiner
I don't know if I'd be that dramatic about it, the $40ish can that I got came with a baffle and drain plug, the insides looked just as good as the LAP3 catch can I had on my kia years ago, and that sucker was like $250ish. Price doesn't always = quality, but in a niche market like this one, you often have to pay top dollar for something if you aren't adventuress.
V6fan
MI
Gee, shocking response from a UPR Vendor.... That may work with the newbs but I’m not a newb.
Catch Cans are nothing but managing vapors. There is no rocket science but you must understand whats under positive and negative pressure, when.
High on Ethanol
Just Ain't Care
USA
I like the mishimoto. Ive seen a few of them installed. Personally I don't use one but I know a lot of coworkers that do on their Mustangs.
If money is no object....radium competition can for each side.
Ecoboost_xsport
Sacramento, CA
I love everything Radium puts out lol...I'm eyeballing their brushless surge tank setups....but so expensive lol...
FiveLeeter918
Tulsa, OK
I'm referring to the JLT comparison most use. I already spoke in detail to the benefits of the UPR earlier, didn't feel the need to again.
There are plenty of "universal" kits out there that can do the job but once you add check valves, baffling if not there, get proper hoses and fittings, etc., you arent off much from the oem fit and finish of the UPR kit.
It really pays to have proper engineering, to know the kit you spent time and money on is actually going to benefit you and not blow your dipstick out of the block when you pressurize the crank.
I'm not here make a sell Im here to educate and benefit the community as a whole. But you also have to realize that you have a $50k car and there are areas you don't want to skimp in quality.
Agreed 100%.
If $350 is too expensive for a needed CC, then owning an SHO might not be a good idea.
I back the UPR because it flat out works.
V6fan
MI
And this is why these posts fail. The Vendor influence is what killed so many messageboards.
This is supposed to be “All you need to know about Catch Cans” and instead its, “just buy UPR for $350+”.
