Jordan's Rebuild Plan of action
Michigan-SHO
Michigan
I'd probably have to relocate the coolant tank to the driver side and the battery somewhere else that would be a decent spot. Just kicking ideas around while the wait is on!
Thinking of Weight distribution putting the battery on the passenger side would be ideal. With the battery out of the way a heat shield should protect the coolant reservoir and intake. Not sure how much your brake lines would like red hot steel next to them...
Jordan_R
Missouri
I've got a baby battery anyways so might mount it where the AC condenser is... Oops more stuff taken out? Still kicking the no AC idea
Michigan-SHO
Michigan
I suppose it depends on how sweaty you are willing get on the way to and from track. Just bring some anti monkey butt powder and you should be good to go!
35ae0366b817034acab1f994d9d2535a
yaycandy
Aerospace Engineer
Hanover, PA
I don't think it'd be all that bad.
Certainly a platform first to my knowledge in the 10yrs I've been with it.
Less cost(s) for piping, but any savings there, would be offset by custom hood work.
Each their own. I'd think it be neat to at least see. Once. Hahaha.
Found one close to fender exit. Side exit has been my thing recently, did it to the old caddy last week after dropping in the new engine...
82HiEzl
2020 06 06 121202
Jordan_R
Missouri
Yeah, that's Greg Eckard's off road inspired build. Not my cup of tea, but props to him on doing what he likes.
Michigan-SHO
Michigan
[mention]Jordan_R [/mention] if racecar is what you are after, why not do a 2 into 1 exhaust from the turbos and just dump out under the car ASAP?
This would allow for an O2 sensor and exhaust gas temp for tuning...
Jordan_R
Missouri
Because open exhaust under the car is no bueno
Jordan_R
Missouri
Enlighten me please. I am woefully undereducated on the subject.
Carbon monoxide poisoning in cabin, but really the reason I wouldn't do it is because it makes the ride painful in the cabin. Extremely noisy and bassy. I have previously driven the car to the drag strip and back with open downpipes. Not very pleasant lol. Best if the exhaust extends out the car or at least to the rear axle with a turn down facing the ground
Michigan-SHO
Michigan
Thank you for the info. I will tuck that away in my “**** not to do” folder.
Fender exit it is!!
Jordan_R
Missouri
Fender exit it is!!
Looking like we might not have much room to do so but would need to see with motor in the car again. It's very tight. That's what she said..
yaycandy
Aerospace Engineer
Hanover, PA
Maybe thats wheres wrong with me.
Photo Jun 06 12 12 54 PM
yaycandy
Aerospace Engineer
Hanover, PA
Nah, I meant open under the center of the car lol. That should be plenty good
Yea it was open hugger type headers for a little while. Its not nearly as bad now, still open headers. Just with collectors, 45degree pipe and a straight pipe till it came out each side.
Jordan_R
Missouri
Trans cooler is in. Trucool 40k trans cooler. Buddy with an LSA supercharged 5.3 with a 4l60 recommended this. If his trans has lasted this long with it it has to be good.
IMG 20200617 133258 917  01
Sho_Ride
Texas
So I told my wife, who has helped me out a lot doing a bunch of small projects on my SHO, that you had commented on my homemade jack stands. I just showed her your latest YouTube video on your rebuild and when she saw the front end of your SHO, she stormed off yelling that if I ever do that, I am on my own lol. Just thought I would share that.
