The infamous SEL SHO
mission bc canada
DO IT! Your only regret will be having not done it sooner. And then you'll begin wondering what to black out next.
Use duct tape to peel most of the chrome that's left off. Then sand what's left. I only used that trick on half of my lights and kicked myself for it.
well - started the switch . 1 down 3 to go!
Joshw0000
North Carolina
pulled it out from the car - 400 grit sand job- 3 light coats of semi black - heat gun between coats .
What's what I did. Well one of my lights has about 5 coats because it developed a bubble so I sanded the paint a couple times until I was happy with.
I also put a coat of wax on each of mine. First 2, after I installed on the car. The 2nd 2 while they were off the car (much easier).
If you use duct tape to yank most of the fake chrome off it'll cut your sanding time in half.
mission bc canada
a bit of moisture in both tail lights - was there before me - anyways how do you remove the trunk lid lights? does the horizontal trim have to come off first ? blackened the lh outer just now - so both lid ones need it .
Joshw0000
North Carolina
I didn't remove the middle trim. I just took a pair of needle nose pliers and pushed the far outter clip through (trim clip). Then take off the 2 plastic pieces securing the light. To remove it, you'll need to slide it towards the inner trim to pop it loose. Then just pull it out.
My old GTP used to develop leaks in the taillights. I used a clear silicone around plastic seams. Sometimes it worked and sometimes not. I mean these things went from getting misty droplets inside to an inch of water trapped on the inside. Had to get new housing for the bad leak one. Couldn't get it to seal right. Manufacture or material defect.
mission bc canada
wife's 06 escape has one headlight like that - I drilled a couple small holes in the corners - really helped - not prepared to do same on my "baby" . might try the heat gun as viewed on you tube vids's.
mission bc canada
hi josh - pressed in on the zontal tap and moved the trim away from lid . nothing snapped whew ! - yes sir ! one's out - all downhill now easy prying on the outer wrap around edges . factory goop not your friend at all. moved it into my garage beside my two mustangs - wow! sits like a truck - foot taller foot longer - glad it has fold in mirrors .
mission bc canada
hi josh - not that difficult to do - used tremclad semi black - has primer in the paint too. krylon would work also.
mission bc canada
Look Ma' no more flakey chrome! - Ford would have been better off with black surround instead of the cheapo chrome - even on the "limited" it would look factory. have rattle can will travel
skyshadow07
Oklahoma
I just love how pretty much every thread on this forum veers off course into some random topic... I'll be sitting there, get a notification that someone has posted about the imposter SHO and instead, we're talking about chrome deletion and how to remove water from taillights and headlights.
markmoomnu
