After the car was parked for about 5 days I started getting "No Key Detected". Car will start with the fob in the fob holder in the center console. This happens with either fob. I replaced the battery in the fob with a new one that reads 3.2v with a DVM.
I disconnected the car's 12v battery and charged it, then reconnected the cables. Same issue. Car only starts with fob in holder.
Also, neither fob is unlocking/locking doors.
No DTC are set. Innova scanner reads 12.8v from battery while connected to OBD port.
Any other tests that I can run? I've read here that an "external antenna" in the headliner can be the problem. How hard is that to access or troubleshoot?
Could this be a fob programming issue and it affects both fobs?
Found this on Ebay, is it the one in the headliner?
https://www.ebay.com/itm/2010-FORD-TAURUS-KEYLESS-ENTRY-ANTENNA-6G91-15K603-KB-/181552675752
