Humming from rear
Scott C.
New Jersey
Can someone help!. Have 13 SHO that at highway speeds the rear is humming so loud sometimes the radio doesnt block it. Could it be the wheel bearing? I rotated the tires same result. If it is wheel bearing, is it a tuff job on the rear wheels with the awd? I have done one in the past on a five hundred.
Sent from my SM-G955U using Tapatalk
krewat
Long Island
If it's a wheel bearing, it's the same as doing a FWD front bearing, basically.
Check the RDU (rear differential unit) oil condition - hopefully it's not that.
Scott C.
New Jersey
Oh brother I hope not. May take it to the dealership to determine what the cause, hopefully wheel bearing then try to do it myself...thank you
SaveMelMac
Texas
Jack the rear of the car up and check for play in the bearing by grabbing the tire
Scott C.
New Jersey
The humming is constant...if I let off the pedal the humming continues...the slower the speed the less.
Crazyeights
SHO Owner
Indianapolis
I had the right rear wheel bearing go bad on my 2015. Very similar to what you are describing. It was replaced by Ford under the 100K drive train warranty I got when I bought it as a CPO.
BadBrad
Are you sure you're not hearing the annoying wind noise over the rear spoiler that I hear right about 80 MPH - or lower speeds but with significant headwind?
Scott C.
New Jersey
Its definitely coming from the wheels...I am going to double check by getting of the ground and run the car.
Scott C.
New Jersey
Well took it on today....was ably to remove all the bolts without issue...however the damn hub would not come out. I tried everything...air hammer, slide hammer, hub puller. Removing one of the studs and using a nut and bolt to force it out. This damn thing didnt even move. I beat the **** out of it. I give uppppppp. I put everything back and going to take it to the garage. I wonder if they will use the hub I purchased. Now that everything is back minus one stud...antilock break light is on...traction controllight on and now making more noise. Please read and take my advice spend the extra money have someone else deal with this BS.
Scott C.
New Jersey
Lol....that's the only thing I didnt try was heat. There is no way I am taking everything apart to try with heat. Monday calling the repair shop and having the car towed. What a nightmare!!!!!
Looking at mrhighcaliber's post in the other thread, I'll retract my no sweat you can do it post. Haven't seen one take that much pressure to release in a long time. And that was a rust belt car that had alot of salty years on it. At least you're not afraid to take a run at it. Post back if the shop has a tale of woe trying to get it to release.
jman1200
Ontario
Well, I advised you on the other thread to not even try and just take it to the shop and avoid the effort and frustration... now you know why I said what I said :biggrin:.
Scott C.
New Jersey
Just car back...they used the part and change the ptu oil...$280. I hope they replaced the oil correctly.
