I actually had those on my Focus ST..... Wider is right. The car was lowered on H&R springs with 25MM spacers in the rear and 20MM up front. Man that thing would rub compared to the old tires that were on it.I put BF Goodrich g-force comp2 A/S on a month or two ago and I like them. The side wall feels stiffer in the corners which makes the car handle better. The BFs are also a little wider than the stock Michelins and have more aggressive tread pattern that makes them look better on the car. You should check them out. They get very good ratings for dry/wet/snow traction and they have a 189mph speed rating.
