I thought about the plate Da bull (Taurus) but thought people would think zodiac sign.
People in the Boise area are "different" lol.
It’s a little nervous right now over bumps as well as being firmer as I expected. I did new shocks and struts as well. Assuming once it settles some and I get an alignment it will be fine.How do you like it? Don't worry it will settle and ride a bit better.
Yes, from Tasca. I actually ordered what was listed on Tasca's site on PP struts but they called and said that's wrong based on VIN. I even had them run another PP car to double check. They were cheap enough I figured might as well since the car has 60k something miles on it.Did you replace the shocks and struts with PP's?
Yup daily driver otherwise I probably would have left them alone.I use reused my PP struts and shocks. They felt fine and I dont drive the car that much to justify spending more. If it was a daily then yes.
All of it will settle. I did the same. H&R + pp shock/struts at the same time. Takes some time to settle and loosen up. Lower tire pressure helps lessen the harshness until they settle. It still will be firm l, but the bounce and harsh edgyness fades. BPD recommended throwing a few hundreds pound of stuff in the trunk to speed the process up. I cosign him on that.It’s a little nervous right now over bumps as well as being firmer as I expected. I did new shocks and struts as well. Assuming once it settles some and I get an alignment it will be fine.
It noticeably settled after a few days. Had an alignment done all better. The rear had some bump steer before the alignment that is gone. It's firmer than it was but slowly getting better as expected.All of it will settle. I did the same. H&R + pp shock/struts at the same time. Takes some time to settle and loosen up. Lower tire pressure helps lessen the harshness until they settle. It still will be firm l, but the bounce and harsh edgyness fades. BPD recommended throwing a few hundreds pound of stuff in the trunk to speed the process up. I cosign him on that.
Very Nice! 4000 DA would be a dream for me!!AJP 93 on meth with 55* 90% humidity and 4000' DA today.
Very nice pull. I see you AJPAJP 93 on meth with 55* 90% humidity and 4000' DA today.
