I recently switched to my 93 octane tune and added 94 oct fuel. Decided to do a few 0-60 street runs using the Torque app to measure them.
I found that when I try launching it between 2-2.5k rpm with the traction control off, there is a sudden loss of power after the wheels spin. I do not hear the engine revving so something is cutting it off. This doesn't happen when I do WOT's starting at idle speed.
I read that that can happen if there is a boost leak. Already checked the reference lines at the top and they are not loose.
I checked YouTube how to check for boost leaks and found a few videos where they cap one of the exhaust tips and blow air through the other one while spraying soapy water on the intake and turbo hardware. Wouldn't this potentially blow debris from the exhaust system into the cylinders? Is there a better way to do it without buying expensive tools? What else should I check?
I also have not been able to go below the 5 second mark so something is not right (or the torque app is not accurate).
Thanks in advance.
Thanks in advance.
