My mtx is compatible whit my v8 sho
Francisco
;) Hi there!! Just want to no!! I got a 1989 sho mtx and i want to made a transmission swap for my v8 sho is this posible? Thanks
Francisco
;) Hi there!! Just want to now!! I got a 1989 sho mtx and i want to made a transmission swap for my v8 sho is this posible? Thanks
It's been done a long time ago. You'll have to use the search function and see if you can find the info. I don't see most of those folks around here anymore. You can also try the v8sho.com email list and see if you can get info there.
firebat45
Edmonton
It's important to note that the transmision from the 1989 will not bolt up to the v8 motor. Converting that V8 to manual is possible, but a complicated swap.
Francisco
what type of transmission can be used to make the swap
firebat45
Edmonton
Any transmission can be used, with an adapter plate and other modes. There is nothing that will just bolt up. Using the SHO transmission makes the CV axle choice easy.
Otherwise there are some Duratec 5 speeds (Contour SVT?) that I believe will bolt up to the motor, but you will need to engineer axles, mounts, and shifter. Possibly clutch.
If you would like to pursue a tranny swap, I am working on one for the SHO V6 and wouldn't mind including the V8 as well. You can PM me if you've got more questions about that.
Francisco
Thanks bro
