Bluetooth Stopped Working - Anyone else have this happen?
SHO1068
DeKalb
Since I purchased my car I have had issues with the bluetooth not staying connected for whatever reason. IMy phone would connect to the car probably 70% of the time the first time, and other times it would only work after I restarted my phone or turned BT on the phone off/on.
Now however, every time I get in the car it tells me it is unable to pair to my device. I deleted SYNC from the setting on my phone, and attempted to re-pair it but the bluetooth is turned off on the vehicle. When I go to phone settings in SYNC and try and switch bluetooth on, it goes right back off. I have also attempted a Master Reset of the SYNC system without any luck.
Bluetooth module went out? Is my SYNC just ***** and I am out of luck?
Any help is always appreciated folks. Thank you.
krewat
Long Island
Is it Sync2? If so, disconnect the battery for a half hour and fully reset everything. I found in my 2013, that the "master reset" didn't fix a couple of issues I had, but disconnecting the battery did.
SHO1068
DeKalb
Sorry, forgot to mention. First generation SYNC (with Voice-Activated Navigation).
Jeff2017
I have an issue where music stops playing over BT. Usually this is shortly after starting the car in the morning and heading to work. But is says it still sees the phone. Just cannot hear the music.
markathome
2010 SHO
VA
I had this problem with some phones. Once I went to Android 8, no problems.
Seems to be the Bluetooth profile on some phones.... At least with my 2010 SHO.
Sent from my SM-G960U using Tapatalk
Tredz
Utah
Did you ever figure out why your Bluetooth didn't work with your SYNC system on your Taurus? I'm having the same issue. Just looking for answers before i buy a whole new unit.
