15 sho non-pp.. h&r spring question.
StealBlueSho
NA
They will fit fine. But how many miles are on your vehicle?
Might be worth getting the PP shocks and struts to go with them.
StealBlueSho
NA
They are a bit stiffer. Not sure if it’s worth paying for newer ones with only 28K miles..
StealBlueSho
NA
Someone else will need to answer this. I ended up with Megan Coilovers.
bpd1151
Lurking Around
SHOcago 'Burbs
I ran the H&R Springs on my 2010 Non-PP with stock shocks.
Was one of the 1st to have done so.
No issues whatsoever.
I have always advocated that the H&R Springs are better than OEM, & that the Megan Coilovers are an even further upgrade over the H&R's.
I did upgrade to the Megan's myself, as I desired to have a greater degree of flexibility, as well as better experiences auto crossing/road coursing my SHO beast.
Anyhow, the H&R's will work with BOTH factory shock options. PP or Non-PP.
Any other questions, post away.
VanillaBoost
Rochester, NY
I just did the H&R springs on my 16 non pp. Car looks way way nicer and ride is very good. Worth every penny. I would also suggest the cam bolts cause
my car was way off after the springs. Cam bolts will make the alignment well within specs.
4sfed
St. Louis, MO
Sorry for resurrecting an old thread but...
1. Will these fit a '15 non-PP with 20' wheels?
2. is there a vendor we like to support?
3. where do I find the cam bolts? Or what do I look for...I assume not the standard ones.
Thanks.
OmaHahn
Omaha
How did you know that THAT is the one? I couldn't find a number anywhere!
I installed H&R about 4 years ago and at that time there were no camber bolts available - however, there was one camber bolt that was the correct size except for the length - it was only long enough to get like 3-4 threads tighten in the nut! But, after 4 years I've had no issues but it's always on the back of my mind that it's not 100% a correct part. The camber bolt I bought then was the 81280. Since then they came out with the correct size for our cars and this is the one - 84130. Several other SHO owners have installed this bolt and say it's the right size, length, etc. I just ordered and received mine - time to install now.
4sfed
St. Louis, MO
Excellent! Thanks!
4sfed
St. Louis, MO
I haven't looked at the suspension yet, so this might be clear just by doing that. However not being in a position where I can do right now; do I need 2 or 4 of those bolts? Are those needed just in the front/rear, or both?
OmaHahn
Omaha
Just the rear - one for each side.
84130 Camber Bolt
OmaHahn
Omaha
None! There's a guy named Jason running 275 tires and no issues. I have the stock size 245 and no issues.
