E-blend?
brucelinc
Aren't you sending logs to Torrie? He should be able to look at your fuel pressure and tell you if you can go higher and if there is benefit to doing so. I suspect you are already pushing the envelope. There is likely a point of diminishing return here somewhere.
bpd1151
Lurking Around
SHOcago 'Burbs
Still true. If you want performance e30 that's it before the hpfp can't keep up.
Korn is correct.
The OEM HPFP has its' limitations, and regardless of the tuner, an E30 percentage as far as limitations therein, are VERY common.
