Catch can
OgreSmash
Austin, TX
Opened it up and it was about 1/4 full. Now do i need to worry about oil in the intercooler still or am I good
Sent from my LG-H918 using Tapatalk
mrhighcaliber
Pull your airbox, pull the upper tube (#15) , and look, scope or dip down in the cac (#25) to the bottom to check for puddling. A little smidge of oil is Normal. Check it once to gauge weather the can is doing its job. 0ed62f37587f472294520d0e0972a08bD9806300c0d7b746b5e43d8fad60ae2f
Sent from my Nexus 6 using Tapatalk
SilverSH0
Most likely you will still need to worry about it. One would assume the catch can is on the dirty side of the PCV system and if that's the case it's not doing anything to keep oil out of the CAC. Oil gets in the CAC when boost pressure causes oil air mist to blow out through the clean side of the PCV system and into the incoming air charge (the connection next to where hose #34 connects).
xFallenxCripplex
What have you used to dip down?
wraitherx
va
Like for heating dipstick or automotive oil dipstick that's on the car?
Your oil dipstick. Just take it out and wipe it off then snake it through the opening once you've removed the piping.
OgreSmash
Austin, TX
the oil that was in my catch can was extremely thick. I'm going to assume its been in there for quite sometime
