SHO max octane
Hutch1
Can anyone give me any reasons why I couldn't try about 5 gallons or so of 110 octane gasoline in my stock SHO.
Sent from my LG-D855 using Tapatalk
Jeff2017
It would just give you worse gas mileage because octane has no energy content. It merely inhibits combustion. I don't see any reason it would hurt your car in the short term.
SHOinVa
Tidewater Va
There is a Gas Station near here that sells 110 "Race Gas", I used to put some in my Harley from time to time just for fun. My concern would be most of them still have Lead which I don't think works well in modern engines. As much fun as it may sound "My Two Cents" I would stay away from it, without a tune to take advantage its not going to help so all you can really do is hurt something. LMAO But if your like me you will probably do it anyway.
C/
Lostneye
NY
I have heard a slight increase over 93 the computer will adjust for but you really need a tune to take advantage. And as said leaded gas is a no no.
Johnbigdog
michigain
Ford's website notes the advertised power numbers were on 93 octane. I guess there is no reason to go over this unless you have a tune and lagitamite need for it.
As noted above high octane is a slower burn/resistance to burn. Cetain is how easily the duel ignites.
Lostneye
NY
Yes but computer will adjust to some degree just as it adjusts to lower octane but you really need a tune to take advantage. And seeing how the only thing available close to me is 100 at around $10/gallon it's not with it unless you are doing a track day.
ShoShane
C/
Virginia Speed sells VP ms109 which is unleaded race gas...I have ran a few gallons of that with a regular 93 tune but I also have another tune specifically for that fuel which makes a very noticeable difference :)
SilverSH0
Unleaded race gas really shouldn't hurt your car at all. It won't really help it, but it won't hurt anything except your wallet. Leaded race gas could **** your cats so I would stay away from that. If you don't have cats, I've heard might hurt your O2 sensors but haven't seen anything to back that up, simply rumor.
