E85 mix?
2013blacksho
Wisconsin
It won't hurt anything I don't drive it that ******* a daily basis should be fine but I'll say that it is got some snap!
Little off subject but can you data log or at least check everything without a tune or do you need a scanner. Is there any software out there that just let's you see what's going on???
DerricksSHO
Michigan
I'm running the race tune. This tune really likes high quality fuel/octane. When I first started running the race tune I noticed my KR would get into mid +2 range on 1/4 mile pulls without the added octane from a slight mix of E/85. With it, I rarely see any KR over (+.8 ) on a clean run... I think it's just letting the tune work to its full potential rather than actually "demanding" more.
Almost a year running race tune now (have not run any other tune since getting it), and almost 2 years straight running an E/85 mix (only a few tanks without it).
Hi SHOnUup do you have any extra monitoring devices on you car to watch parameters? Im wanting to get the race tune but wanted to talk to you before hand and find out what all I need. Thanks
SHOnUup4
SE MI
I use a scantool that displays gauges via the Torque Pro app onto a tablet I have mounted.
I'm just over a year into running the race tune now. It's been on multiple long trips through many states with zero issues.
Same tune I run at the track for a best of 12.05 now, also gets 27 mpgs at 80 mph on the freeway.
If you're tuned, regardless of having "race" tune...I'd be monitoring.
DerricksSHO
Michigan
is your race tune custom? which scantool do you recommend coming from a mustang ive used sct and am new to the Torpue Pro app them are awesome times and hope to be there soon.
SHOnUup4
SE MI
Race tune is the same one all of the Livernois customers get with my strategy code.
I'm using the OBDLINK MX Bluetooth scantool...should be able to find for $79 now compared to the $99 it was 2 years ago. I feel it is the best one for smooth delivery of data, but I'm losing faith on its quality. I'm on my 2nd one and it has begun to act up and not work all the time.
It's taken a LOT of track time and tinkering with setups to get the times so far.
Keep track of temp, tire pressures, and launch rpms to find out your best configuration for achieving your goals.
StealBlueSho
NA
LMS re-wrote the 4+X race tune for my strategy to match what yours is... I complained that the race tune I received was a bit slow.. afterwards based on initial logging it took a .2 seconds consistently off my 0-60 times... Although I get NO knock so I don't run ethanol...I get full advance on the 93 we have out here..
DerricksSHO
Michigan
awesome.. Just ordered the bluetotth OBD2 off amozon I got the BAFX unit for android. What parameters should I watch IAC temp, wide band choice? Thanks for the help.
SHOnUup4
SE MI
Might be sneaking out to the dragway tonight...we'll see. Leaving for Ohio tomorrow for a weekend birthday trip for our TEENAGER (yowza, times a flying) and a couple of his buddies. If I can complete my massive to do list that is...
D398cd13c773ffee5d9b85a0197cdb16
steelgiant5
F40f9a9524ef58ce150e97e7b595df6f
This is what I watch
Whole lot of shit on that screen. I have just been using my sctx4 and have 6 gauges on it mounted on windshield.
Usmcsho01
How did you mount it?
Sent from my XT1650 using Tapatalk
SHOnUup4
SE MI
My mount is similar...little longer of an arm. $20 from Staples.
steelgiant5
Mine is made for sct x4.. they prob don't sell that at staples.. lol.. you have a Samsung tablet right?
SHOnUup4
SE MI
It's called a Tab2...old it is. Think it's a Samsung though
Sholab1
United States
Best but has the Samsung tab A 9.6 inch screen for 179.00 this week. Soche mount actually sticks by radio, and there is enough there. I it blocks controls but you can us touch screen control's instead C29fde1d4f60bc9f0e4ae808d3b87044
Sent from my XT1254 using Tapatalk
