Okay Livernois I am hooked after wrecking a scat pack up to 100 then he passed me, but with just a tune thermo 3map and CAI I'm impressed. What's next that will give me decent power gains that won't break the bank?
What about water meth injection is that not recommended?
And do you have a pack with downpipes and catback together and maybe add meth kit with it?
No we do NOT recommend using any type of WMI kits. Think about it for a second...a TDI engine's intake manifold is where (like NOS in other applications) you are introducing WATER. Ever heard the saying water and oil don't mix? That could not be anymore true for your EcoBoost! Is water a good cooling agent, yes. However, there are other ways to achieve superior cooling without the introduction of water, like having our deck brace system!
The factory 3.5L Ford Ecoboost block is built with an open deck configuration. This open deck configuration has a series of advantages in the stock application, such as ease of manufacturing, cooling, and lower weight.
However, when pushed beyond the stock power level, this open deck configuration becomes a problem. With the cylinder bores floating freely, there is no structural support to keep their position relative. Additionally bore geometry is affected at higher power levels as the bores distort and shift because they lack support. The head gasket faces increased loading and shift as the bores move under heavy load, leading to possible gasket failure under load.
All of these problems are big issues for a higher output 3.5L Ecoboost engine, as more boost, larger turbos, and upgraded parts allow for nearly doubling the output of the stock engine. Without some method of stabilizing the cylinder bores the engine will have reduced performance, and most likely eventually suffer a failure.
Livernois Motorsports has taken and applied it's extensive background in block modification for racing and OEM development and created a block and deck brace system for the 3.5L Ecoboost engine, which offers significant increases in strength, durability and performance,
The Livernois Motorsports 3.5L Ecoboost deck brace system is designed from a pair of billet pieces of 6061-T6 aluminum and is machined to perfectly fit into the 3.5L Ecoboost block. Exacting tolerances are used to ensure a precision fit, as well as the best performance. Using high strength aluminum allows the brace to closely match the factory aluminum's expansion rate, which allows the brace to expand and contract at the same rate as the block, keeping the bore geometry as it should be. Additionally, the brace is machined with cooling passages that match the factory 3.5L Ecoboost head gaskets, as well as other machining steps to ensure that the head gasket is properly cooled.
When final machined, the deck braces look as if it were part of the OEM 3.5L block, perfectly matching the parent aluminum of the block, and offering a seamless and perfect solution to adding significant strength, durability, and performance to a 3.5L Ecoboost engine.
We do not have a bundle with our DP, CB and methanol injection. There is actually good reason for that! We do not recommend the average modder to attempt to install a meth system. It is extremely intricate. There are several major things that need to be done in order to install a meth kit correctly. For example, removing major sections of the body, drilling into the frame and tapping into wiring. It is VERY involved, as you can see. On a 1-10 difficulty scale it is about a 12. We routinely have shops that incorrectly install meth kits on EcoBoost cars and trucks. Installation is only part of the battle! You still have to be able to calibrate the system correctly. There are several gain adjustment knobs that need to be altered in order for your kit to work correctly.
Good question!
So if you actually look at our Machine Shop Services you will see that we have a tool that you have likely never even seen before, a ROMER Infinite 2.0. The ROAMER can be affixed with several differently styled tools for different types of measuring, probing and/or digitizing. What this tool allows us to do is actually use its arm to take data points, log those points, reproduce them into a matrix and then recreate that part into a completely manipulatable 3D image.
So once we have all of those points transformed into a viewable/manipulatable image we can then sit down and review that recreated matrix. This allows us to take measurements on all 5-axis'. Using all of those measurements we can use our MasterCam X7 with Port Expert, Solidworks 2012, Camplete port and Verisurf X softwares to engineer a deck brace.
This is fun. Good answer! The cutaway photo is worth a thousand words. PRESS is the word I love the most. One day, we will meet.Seeing how the ROMER did not sell their measuring tools in the US until 1989, I would have to say that the 30 year old pictured is a tad bit older. Furthermore, the INFINITE 2.0 was not released until 2008. Just being a stickler for chronology. Especially since the guy you mention in the picture happens to be me.The complete INFINITE 2.0 system (without probing tools) is also quite expensive. As they typically have a starting price of ~$30,000.
The entire piece is machined to match the spacing of your particular deck to perfection. We have actually tried to install the deck brace similarly to how you described. The problem is that you cannot make the braces to the same stringent tolerances that we do currently if we were to make them your way. This would eliminate much of the structural integrity of the brace. Post machining the brace we actually have developed a proprietary process for pressing the brace into place. This process is very similar to the one that we use when installing our proprietary sleeves.
The brace adds significant strength to the block, deck and bores. This ensures that even under high boost conditions where power and load go up considerably, that the bores don't shift and move due to the factory open deck design. In addition, to strengthening the bores and improving ring seal under load the brace also improves the head gasket retention and sealing, preventing gasket blowout. This brace kit offers a much needed improvement in bore and deck strength for the EcoBoost 3.5L engine. The factory open deck block architecture works well at OEM power levels, but can quickly become strained in higher boost and power applications. This bore brace adds significant rigidity to the bore and deck. This allows for much higher output without fear of failure from bore deformation or gasket blowout. The increased strength of the deck surface prevents gasket creep and eventual blowout. The design of the brace with its integral cooling passages built in allows to maintain the proper gasket temperature as well, and also allows for coolant passage between the cylinders. Livernois offers this system with included machine work necessary to upgrade your 3.5L EcoBoost engine to the ultimate in durability and performance.
