License plate bulbs
Sir Allecrop
New Jersey
how do you get the house out to change the license plate bulbs. I want to put leds in. Took the screws out but couldn't figure out how to get the housing out
What MY is your SHO? Sorry if the Q seems redundant, but I don't see a sig for your ride ...
gandyj
It's a 2015
If the tip of your phillips screwdriver is small enough just stick the tip of it into one of the screw holes and just pop it out. There is rubber seal around the bulb lens making it a little snug.
Sir Allecrop
New Jersey
Tried prying it out with a flat head screw driver. I couldn't get the housing out. Felt like I was gonna break it. It's making me mad
EcoBoostSHO
While the lens cover should come off with a little tugging the whole housing comes out easily if you use a small flat head on the side where there is a little indent. It's hard to spit but its there. Push in and it should pop right out. They are 5.50 a piece with new bulbs fro. The Ford dealer so you could always just buy new ones and drop them in. I just did this...
Sent from my XT1096 using Tapatalk
EcoBoostSHO
Side of the outer black housing...it's almost impossible to see but its there
EcoBoostSHO
Just start on one side. Slide the screwdriver in to the notch and keep pushing with moderate force as you have to push a plastic clip in some
BlueSHO
Which LED's did you put in? Any pictures?
Sent from my DROID RAZR HD using Tapatalk
OmaHahn
Omaha
I just installed some from AutoGlow - the most pure white color I've seen! I had some previous LED license plate lights installed but the had a hint of blue and looked cheap to me! These ones look factory, like the ones that came on my Audi!
Please update how you like the performance of the AutoGlow bulbs over time, and add some pics when you can. TIA.
gandyj
I installed the entire interior light kit from auto glow except for the trunk light (went a different route) just a couple of days ago and like them a lot.
