Wonder how the flow compares between the stock, LMS, and Reische thermostats?
In the end, the opening temp is not near as important as the total cooling capacity of the system. Regardless of the opening temp, the car is going to operate at the same temperature if the cooling capacity remains the same.
The difficult part to know is if the capacity of the system from the factory is being restricted by the flow capabilities of the stock thermostat. If the cooling system is capable of greater cooling capacity, then a higher flow thermostat will be of help. Not lower temp, but higher flow.
In my other car, I have a aftermarket aluminum radiator that greatly increases the cooling capacity of the car. That paired with a 180 high flow thermostat keeps it actually running at between 180 and 190 degrees.
The fact that we see our cars getting up to the same temps with these lower opening temp thermostats tells me that the thermostats are either restricting the flow or our cooling systems need more cooling capability.
As for the LMS vs Reische debate. It's a really convoluted debate. LMS used to sell the Reische thermostat. They now private label their own thermostat. To make it even more confusing, the Reische used to be a made in Germany piece, but now appears to be a modified Stant that is made in the US. So, when comparing we have to be specific about which version of each we have.
My 170 Reische is the new, made in US, version and seems to have my car varying temps from 176 to over 200. I don't like to see that much variation. If the cooling system was functioning properly, it should operate within a more narrow range. On the bright side, it does not generally stay over 200 for a long period.
In the end, I think the stock thermostat is completely fine and will have your car operating at the same temperature when driving down the highway. The primary benefit of the lower temp thermostat will show at the track when you are able to make a pass and have it open up sooner to help with heat soak and start the cooling process sooner for the next pass.
