From the little bit I know, I think the Under Hood Fuse Box is live, even when the car is turned off, and that is when your loss occurs.
If you have the luxury of the 2-week drain test, then you could narrow your search to the downstream wiring of the big connector, by uncoupling the connector and hooking the battery back up. If there is no drain over a period of time, then you know it is in the disconnected branches.
If the drain is still there, it could be this same wiring that is upstream (to the under hood fuse box), or some of the other wires that leave that fuse box and do not go through this connector.
Situation 1 (uncoupling means drain stops) means one of these branches has the short or drain and it could be:
Wire Bk/W - power seats, locks, key-less
Wire BK/Y - rear defog
Wire BK/O- lights and fuse pane
Wire Y - ignition switch
