2013 PP looking for around 500 hp, what to do?
Fxfordguy
Bonney Lake
I pick up my new to me Sho this Friday and I want to hit around 500 engine hp. I'm thinking of the upgraded turbos and intake with down pipes and a tune what kind of HP are there making with these parts?
EcoPowerParts
AZ
On pump gas you can easily get to 450WHP with those mods. I can set you up with a package for the turbos, downpipes and tuner/tune. I would also suggest a meth kit as well to help support the additional power.
Livernois Motorsports
SHOForumSponsor
Dearborn Heights, MI
Good morning Fox. I see that you have a goal of 500 HP, there actually is no need to upgrade the turbos to make that power level a reality. We here at Livernois Motorsports have a package that will easily get you to your goal of 500 HP WITHOUT ever lifting anything heavier than a few wrenches! For the guy that wants to SHO up anyone that is unfortunate enough to rev his engine next to you at a light we have the SHOSTORM2 package! With this package you will be in the 525-535HP range, without ever having to do anything more difficult than "burping" your coolant! We are the current world record holder for the most powerful EcoBoost platform on the planet. 2010 SHO (#690 of 1,064) WORLD's HIGHEST Horsepower Ecoboost SHO!! 617AWHP 608AWTQ! And, the best part is that it is a DAILY DRIVER! We even have 2 builds going on as we speak that will CRUSH the current world record!
The SHOSTORM2 performance package consists of ALL EXCLUSIVE LIVERNOIS MOTORSPORTS PARTS!
Livernois Motorsports Exclusive Custom Tuning
Livernois Motorsports Exclusive Windstorm Cold Air Intake
Livernois Motorsports Exclusive EvenFlo 160 Thermostat
Livernois Motorsports Exclusive Thunderstorm Catted Downpipes
Livernois Motorsports Exclusive Thunderstorm Full Cat-Back Exhaust
3 BAR MAP Sensor
Pre-Gapped Spark Plugs
We do offer packages that will get you even higher gains. The only limitation is your imagination!
The package is so new that it isn't even on our website yet. You can either PM us or call, and we will give you all the info!
__________________
Performance driven, race proven!
Specializing in the most powerful and exclusive performance parts
Current EcoBoost world record holder on multiple platforms!
http://www.livernoismotorsports.com/
Shoplus80
Jacksonville FL
This sounds to good to true! What if you have already have the following upgrades: AIRRAID cold air, Steelworks downpipes would you be able to still get that kind of HP of the car?
Realistically, you need at least:
Tune
Downpipes
Methanol Injection Kit OR Stage 2 Turbo Kit
Lower Temp TStat
Properly gapped spark plugs
to get a sustained, DD type, streetable 400 AWHP (about 500 hp at the crank). If you have meth AND turbos, another 50-60 AWHP. Add a freeflowing exhaust with cutouts, another 20 awhp easypeasy.
Can you go beyond that? Yes, for sure. 700 crank hp is the rumored factory limit for an unmodified 3.5EB engine. How usable is it, and how much do you have to invest? You will need suspension upgrades in addition to engine upgrades at the very least. Coilovers, traction bars, etc might be in your SHO's future.
Is your SHO PP-equipped? Then you will have a cooler and temp monitor for the PTU (yay!). Plan on a regular PTU & trans fluid change routine to keep the grin on your face from fading.
GlassCityKicks
OHIO
Tune
Downpipes
Lower Temp TStat
Could you elaborate on "Is your SHO PP-equipped? Then you will have a cooler and temp monitor for the PTU (yay!). Plan on a regular PTU & trans fluid change routine to keep the grin on your face from fading" Thank you!
Devin
3.Slow
Pacific Northwest
Which part? The PP (performance package) or the periodic fluid changes (heat causes oil to break down, more heat will cause it to break down quicker)?
Jean
3 BAR MAP Sensor
__________________
I have a 2010 SHO can you pls tell me how much it would cost me to reach 500HP?
Tune + 3 bar MAP + TStat would get you pretty close to 500 CRANK HP, definitely at least 450-460. Then you could do the entire intake/exhaust (CAI, downpipes, catback) or methanol injection to get you to or past the 500 mark.
SHOForumSponsor
Sure thing Jean!
To go full bolt on you are looking at around $3500 to your door. That would put you around 500hp. Now, if you want to be at 500whp...that is a different animal all together. That would require methanol and a turbo upgrade kit. Still very attainable, but it is not as easily done.
gmisner94
Toledo ohio
I have a 2013 pp with catless dps. I'm looking into doing intake, tune, tstat, gapped plugs, 3 bar, and a methonal kit. I'm wondering what this would cost and around what range awhp I'd be in?
SHOForumSponsor
If you want us to install everything for you, there is a definite lead time as we have about 60 cars in the shop right now. There are about 30 cars waiting for tuning ATM. I would need your contact info so that I can have my installation specialist, Steve get in touch with you.
gmisner94
Toledo ohio
Well I was really just looking for an estimate on how much a shop would charge. I know all shops are different but I was hoping to get a rough estimate. Also if I was to do them things plus the atp turbo upgrades would the engine and tranny be safe With out further upgrades to them?
SHOForumSponsor
For any kind of installation estimates you would have to talk to Steve.
Even the WR holder is daily driving his car on the factory trans. Nobody has an aftermarket upgrade to for the trans.
