Shocks and Stuts
Texas
Time for new ones, original ones are showing age (58k miles).
What is out there for replacements, or has everyone gone back with factory?
mphowington
ga
This is probably more complicated question then you think. The ultimate answer depends on your objective. Track ready? Daily driver? Occasional driver?
OEM replacements tend to work well. In my old sho from ****- a 91, it had a suspension gremlin- I ended up putting in midgrade Monroe and it worked fairly well- for a comfortable ride and a decent setup. I drove it primarily and was pleased- and of the car was a DD- long commute, it would have been fine. For occasional track setup- ehh probably wouldnt have been happy.
What year is yours?
Texas
It is a 2013, PP, car.
It is my daily driver... 175 mile per day commute.
It has never been to the track, and probably never will.
Seems like my best bet is to go back factory.
Megan coilovers are in the works, delayed I think due to the racing season having started. Factory is still the best option ATM, or you could go a fancier route and have an air suspension installed (lose some trunk space).
mphowington
ga
If you are sure you need shocks- Id recommend OEM then- that young of a car, with that low of miles- seems odd the shocks would fail so quickly- but if thats the case- look for OEM and you should be content with the performance.
esfoad
Esfoad
New Jersey
I picked up my 2010 about (47k on her) seven weeks ago and have already dumped nearly $3,000 into repairs. Front struts included.
Sorry for you. I hope it wasn't abused before you got it. Hey, I live in NJ where the *** holes this year were massive so I know sh** happens. In my case, I had a bent rim 2 years ago that needed repair. I'm not saying the shocks/struts will definitely last but typically they last longer than 50K miles or so. I guess I was lucky. That said, use a quality replacement and you should be good for a long time.
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
My recommendation would be Bilstein HD if they make them for the Taurus. My note is I replaced them on SUV but based on their results I feel comfortable making the recommendation. Might I also recommend that you strongly consider a SHOCK/STRUT Combination unit...It might be more expensive up front but overall could be cheaper for install as it is a fairly simple plug and play replacement. Check with your local mechanic or parts guru.
Torsen
Nashville, TN
I wish they made them. I can't find anything better than the Motorcraft struts.
SHO_Fast
Meet the new Boss...
Muskegon MI
I put Monroe SensaTrack all the way around on my 2011 SHO non-PP daily driver at 85K and am pleased with both ride and handling. I also put new Pirelli Cinturato P7's on at the same time so I can't speak to the before and after difference, but altogether it is a better, smoother handling ride than before.
jontyrees
Austin, TX
Personally, I'd go with Motorcraft OEM. Was there anything about the shocks that you didn't like previously? I'd use that as a yardstick for whether you need to change them, and what you might change to.
