New Headers With or Without EGR Ports
sblackburn23
'92 SHO Driver
Indiana
So I am going to go and do a full exhaust system buy from SHO Source and I'm planning to go catless, but I have an option on the headers that I don't know what I should choose. I have an option to go with EGR system ports or not and I'm wondering how difficult it will be to reroute the EGR system and if I will get CELs or just how generally difficult dealing with the EGR on a '92 is.
Thanks in advance for allowing me to tap into your knowledge.
SHOspazz92
Banned
Triad Area, North Carolina.
The ONLY V6 SHO's to come with a EGR system was the 93-95 ATX (Automatic cars) and California MTX (Manual) cars. You first need to confirm if your car is a California car and if it even has an EGR System.
-Sam
if your car has an egr system, then you either need to plumb in the egr system in the new header setup, or you need to get a tune with the egr stuff deleted, otherwise you will have a permanent "cel" and have emission test issues if you have those tests.
AREA 91
Area 91
Since I am one of the few who has headers on a sho v6, I'll give you some advice.
I highly recommend that you have a high temperature coating applied to them. They put off a lot of heat, and there are no heat shields in place like the stock manifolds.
I also would wrap the fan, starter, and alternator wiring harness with a high temp reflective heat wrap.
As far as the egr bung goes, get them without it unless you are a California mtx, or an atx.
When I purchased mine, I didn't have a choice. They all had the egr bung. I just welded it shut.
Welcome to the header club.:evilgrin:
