SHO Parts For Sale
K-Dawg
Treasure Coast, FL
Some of this stuff isn’t worth much, and it’s going to go in the garbage if it doesn’t sell. So don’t be afraid to make me an offer that makes it worthwhile for me to package and ship.
I also have a couple engines sitting around with some parts on them, and have several bins of nuts/bolts/hardware, so if you’re looking for anything not listed, ask me.
Finally, I’m working a lot right now, but I’ll do my best to get things shipped out ASAP.
Pictures here: http://smg.photobucket.com/user/kelvinturner/library/For Sale
Added on September 15, 2014
1991 Taurus/Sable/SHO Factory Shop Manual w/ Electrical/Vacuum Troubleshooting Manual $35 shipped
Added on July 13, 2014
Mocha dome light for non-sunroof car $20 shipped
Added on July 7, 2014
NOS Ford Gen 2 Blend Door Actuator (F3DZ-19E616-A or F3DH-19E694-AA) $75 shipped
Parts added on June 29, 2014:
DIS Module $40 shipped
Coilpack $40 shipped
NIB IAC - BWD 21760 - $35 shipped
Alternator from a 1993 MTX (recently rebuilt by an independent local shop) $70 shipped
1991 Canadian Slicers (non-directional) with center caps - make an offer
I also have a couple 3.0 engines worth of parts.
Interior
Gen 2 black dome light (no moonroof) $20 shipped
Multi-function stalk $20 shipped
Driver side rear window motor (almost new) $20 shipped
Gen 3 steering shaft w/ boot $25 shipped
Exterior
Gen 2 front airbag crash sensors (2 available) $15 shipped each
Gen 2 center high mount stop light w/ gasket $50 shipped
Green 93 spoiler $50
Engine/Trans
Stock MAF $40 shipped
Power steering cooler $25 shipped
MTX tensioner pulley brackets $15 shipped each
DIS module – cracked on one end, but fully functional $40 shipped
Later V6 coil pack (offset tab on connector) $40 shipped
MTX w/ 85k miles $250
Suspension
NIB Gen 1/2 Tie Rod ends MES2513RL $15 shipped per pair
artsho
New York
I need the Timing belt crank sprocket $20 shipped.....Is this the part on the crank that the timing belt goes on?
Dinosauro
Pasadena, So Cal
Gen 2 instument cluster
Hi Kevin -
If speedo and other gauges work, send me the cluster for $20. I'll pay you with PayPal if OK.
Thanks,
Dean Price
Dinosauro
SHO_Mike
Fort Lewis, WA
Would you happen to have the following:
-3.0 tensioner stud
-3.0 oil pan
-3.2 timing cover
-Cam chain tensioners (with not too much wear)
-Crank bolt
-Full set of intake bolts
-The 2 bolts for the throttle body
-DIS bolts
-3.0 accessory brackets with bolts
Pretty much looking for any pieces I may need for a 3.2 swap.
K-Dawg
Treasure Coast, FL
I think it will work if you cut off the tab on the connector. Unfortunately I won't have time to look at what I have for about 2 weeks.
K-Dawg
Treasure Coast, FL
Bump. I'll be adding some more parts sometime soon. Also, I'll be at the Convention in Fort Worth and will be able to bring just about anything listed.
313tiger
