ABS light flashing code 42-need help
1995LOUDSHO
Xenia
So couple days ago airbag light starts flashing. So then I noticed the sequence and searched on here to find its code 42.
Center radiator primary crash sensor.
Suggestions on where this is and how to fix it?
Thanks in advance
Darrin
Fordlover96
Virginia
Now, I don't really know much about these systems, but......why would the ABS light flash a crash sensor code? I thought that was the job of the airbag light. So is it a code 42 on the Anti-lock brake or Airbag system?
Fordlover96
Virginia
Now that that's cleared up, haha, the reason for the fault could either be bad wiring, bad connections, or a bad crash sensor. The sensor itself is located on top of the radiator, below the little plastic information panel thing. Anymore information would have to come from the more knowledgeable SHO people.
1995LOUDSHO
Xenia
Ok, I will have to inspect everything and take it from there. Easy enought to get to at least
either the connector is bad or the sensor is bad. if you need a sensor, see my parts for sale thread.
1995LOUDSHO
Xenia
Ok and I'm guessing the sensor. Is it large? Looking into it now.
Also if helps when you turn car off, with key on it makes a beeping sound. Beeps 5 times, stops and repeats over and over until the car is turned off
Ishodu
More often that not it the wire has gone bad. There is a bad area for a connection to come apart right around the air box.
1995LOUDSHO
Xenia
Ok I will check into that.
Does the beeping help indicate any of the issue? Beeps 5 times and repeats this with just the key on but not while running
1995LOUDSHO
Xenia
So I'm pretty ire it's the connection somewhere
As it went off for awhile and comes and goes now while driving
