Piston ring end gap question
waffles
Hello sho pros! I am moving right along in my 3.2 build for my 93MTX and I'm at the point where I need to order some rings. Here is my concern: I measured all of the bores with a telescoping gauge at 3 depths taking 2 perpendicular measurements (3 in each direction then wrote down the average) and everything is golden, it's even toward the bottom end of the spec. when I took the pistons out the rings were seized in the lands and it has been that way for years as this motor has been sitting a while. When I measured the ring gap it was huge! Bore #1's top ring was at .025 when the spec is .012-.018. MY QUESTION: Does ring end gap of the old rings dictate which new rings I need? The bores are well within spec so I would guess STD rings would be just fine, but this is my first build. Any help is greatly appreciated!
Phoenix
SHOHOLIC
QC , Canada
if the block is ok, slap on hastings rings and call it a day , just a very very light honing of the block would be nice though.
waffles
Thanks man, I was just going to tell the machine shop to very lightly hone it when I get the decks checked anyway. So STD it is?
Also is there a significant performance gain to getting larger rings and filing them?
jimtash
nc
I got tighter end gaps from DNJ rings. Had to actually enlarge them a little they were so tight.
Phoenix
SHOHOLIC
QC , Canada
yes , what rcm sells , I think hes the only one selling hastings
waffles
I was planning to buy from him, but he didn't know whether to get STD or +20, I'm pretty convinced that STD will do, Do you know anything about his return policy if they don't work?
standard ones will work fine. the larger gap on the old rings is due to the fact that the outside edges of the old rings have been worn away some due to usage, and that wearing of the outside of the rings results in a larger gap.
I would check the new rings and gap them at the high end of the factory range. That way you don't have to worry about having the gap close up when you are running the engine hard. If you are planning on any boost ever in the future, gap them at .020-.025"
waffles
Your answer has flipped the "duh" light on in my brain, thank you! So I was at the ,machine shop today and the guy told me the same thing, and that I had a few bad ridges that the hone might help with, he didn't want to ridge ream it, but he also told me to get moly rings. Why would he say that? I don't even think there is moly rings for the SHO? Anyone want to shine a light on this?
AREA 91
Area 91
The top ring will be a moly type, unless you got Chrome rin
gs which you do not want.
moly rings are supposed to both break in quicker and last longer.
jimtash
nc
Look into Rockauto's house brand DNJ. They are good quality and have the same design as Hastings.
jimtash
nc
DNJ Piston Rings consist of Chrome, Steel, and Cast piston rings
which will withstand the new model engines with computer advancement and older engines. DNJ Rings are designed and manufactured for a quick seat and a long life.
http://www.enginecomponents.com/piston rings/piston_rings.html
They are the exact same as Hastings. Even the 2nd ring uses the same wiper design. And they are chromed on the outside.
waffles
Thats funny, I might just have to snag a set, $85 sounds a lot better than $120!
jimtash
nc
I like them better than Hastings. Ask 914 about what he thinks. He put a set in his set up as well.
3d914
Here's the results of my gap check on the set of DNJ I bought for the 3.2.
Been running the motor since to help the rings seat so don't have much feedback yet. Had good compression on all cylinders, though one was at the low end of acceptable. I suspect the rings gaps may have rotated some when I installed that cylinder. I'll check it all again after 25-30 hours of running it.
jimtash
nc
Did you hone the cylinders? I remember mine were in the 14 range for the first rings and in the 18 range for the second. I went ahead and took them up a little I recall. 16 and 20 I think is what I ended up with.
waffles
I told the machinist to "very lightly" hone them. Thanks for the tips gents
