info on subframe connectors
taurus94
ontario
i was looking intosubframe connectors for gen 2 taurus. but seem pricey and i can have a local welder build me a set but im just uncertain as to where they weld to front and rear... if anyone has any info or pics etc, on weld on or bolt on subframe connectors id be very very thankful
thanks!
SHOVNST
Blood type: SHO+
Niwot, CO
This link says that the car should be on a wheel lift when welding. I've read in numerous other threads that it should be on a chassis lift and not a wheel lift. Which is the proper way?
I have no hands on experience installing subframe connectors but common sense tells me a 'drive on' lift is needed for installation.
jayro
Auburn, In
When I was looking to install mine, I found exactly what you are talking about. I don't remember which I ended up doing on mine, and to be honest I am not sure if it really makes a differance in performance. They are to keep the body from twisting/flexing, so once they are welded in they are holding the body rigid in whatever position it is in.
They are a great mod for anyone who plans on doing any performance driving. There was a very noticable difference after they were installed.
Ishodu
Where do you live in Ontario? I have built and installed at least 15 sets between my house and SHONUT's house in Cornwall. I have either used a lift or jack stands placed in equally spaced out distances to make sure everything was exactly even prior to install. Then used a jack or tranny jack to hold them up against the body to weld them on.
