Balancing when changing pistons.
zach44102
BIG TURBO
Georgia
Having Wiseco make me a set of pistons. Using the original crank and KOB rods. Should i balance the rotating assembly with these new pistons or just grab a gram scale and make sure each piston/rod assembly comes within a couple grams?
are people swapping pistons in sho motors with balancing?
zach44102
BIG TURBO
Georgia
I just did some research and I think this is something i can do myself with a gram scale. Minus the crank. So now my question is how well are the cranks balanced from the factory? I can weigh each rod and piston myself and take off material as needed.
AREA 91
Area 91
You would be foolish not to get the rotating assembly balanced.
zach44102
BIG TURBO
Georgia
After everything I am without a doubt going to get it balanced. Only reason I asked was because I had seen people swap pistons in other applications without a balance.
Should I balance it 50/50 or can there be any benifit of balancing it differently? Also rods?
Should I mess with the rods at all? I have heard of people re sizing them or should I just leave them alone.
AREA 91
Area 91
Search and read.
http://www.enginebuildermag.com/Article/48121/understanding_crankshaft_balancing.aspx
