Off Road SHO
Moderator
It's #19 that has me bugged, as it shouldn't see ground on the plus side of the FP circuit unless the FP were on. Gonna tackle that one tomorrow - I hope.
I think that reasoning is not right. As an example, you will see ground on the hot side of a light bulb. How is that possible? If the ground side of your fuel pump is hooked to ground, you will have a path to ground from the positive side. You have to, that is how it works. As soon as you supply +12 volts to the hot side, the device will do its work.
I think you're over analyzing things.
Tom
