DEAD 1990 Ford Taurus SHO Blu
kartmonkey9
Grand Rapids
Selling my blue '90 SHO. recently died on me. the car does not run and does NOT turn over. something is keeping the crank from turning. Ford Dealer couldnt even free it. havent taken anything apart yet.Do to limited time and funds at this time, Im seeing if anyone is looking for a project car to put a new motor in it or do what ever with it. The car ran and drove great before it died.I bought the car from Matt (calypso) last year who bought it from another forum member, Dave Kegel. selling the car as is, minus the stereo.
car has alot of good parts and body has a lot of life left. just dont want to waste this beautiful car parting it out. cant get pics loaded up. give me your email and will send pics apon request.
asking $1500.
here are a list of mods/parts on car. also has a new stock clutch and flywheel with about 1500 miles on them.
MODS:
Drivetrain:
3.2L engine
SHONut +40 cams
Ford 80mm MAF
SHO Shop air "horn"
Underdrive pullies
155 lph fuel pump
Dual-core radiator
Midwest SHO Y-pipe modified with true 2.5" collector
Fully mandrel bent 2.5" exhaust with Dynomax race muffler (resonator)
Edelbrock Muffler
Tweecer RT
Gen3 subframe bushings
SHONut reinforced motor mounts
Last dyno was 230HP/195 TQ. HP peak is 6700 RPM.
The A/F ratio is not yet optimized. With a wideband O2 and some more twEECing, I think there's more power in it.
Suspension:
Intrax Springs
Tokico struts
20mm front bar w/greasable poly bushings
TRW front lower control arms, tie rod ends, sway bar end links
26mm rear sway bar with Delrin bushings
Heavy duty rear sway bar endlinks
BMR adjustable rear lower control arms w/greasable poly bushings
Rear control arm center H-brace
-2.5 degrees camber front, -2 rear
Brakes:
Wilwood BSL 4 piston front calipers
Wilwood PolyMatrix B, E, and T pad sets
12.2" x .81" 2 piece vented front rotors w/aluminum hats
10" vented rear disk brakes w/Porterfield R4-S pads
Rear brake bias valves
Stainless steel brake lines all around
ATE brake fluid
Wheels/Tires:
17x8 Borbet Type E w/235/45-17 Toyo Extenza HP’s
kartmonkey9
Grand Rapids
sputtered for a second then died. started back up and ran for a few seconds then died again. wont crank over now.
Huntervf
Bored now
Back in Michigan ... again.
Interested, and I'm an hour north of you. But I'll be honest--it doesn't run and from the sound of it the engine is now a paperweight. You could easily part it out for more than I would offer, but if you want it gone and don't want to see it parted, I'm your guy.
thatSHOguy101
