No fuel injector pulse
srt4man
WV
Car runs if you spary fuel but the injectors are not spraying Any Help would be greatly appreciated .
mattsho1993
SHO owner
albion, new york
i cant remember what i did to fix it but i had same problem a few years ago.... I think it was a ground on the fuel rail...
Off Road SHO
Moderator
Thomas,
The injectors are commanded to fire by the PCM; which uses pulses of "ground".
So, you've verified that you have 12 volts at the injectors by back probing the red wire at each injector with a grounded test light?
You've also verified that you have at least 32 psi of fuel pressure at the Schrader valve on the fuel rail behind the throttle body?
You've checked to make sure that all the original grounds of the wiring harness in the engine compartment are still grounded?
You've checked to make sure the PCM's pin 20, 40 and 60 are still grounded?
Tom
AREA 91
Area 91
Check the ground wire in the valley of the block, near the knock sensor.
auto.guru
Village Idiot
Neenah WI
When my ccrm wasnt grounded properly the Injectors wouldnt pulse. Check the ground wire (black/green stripe) near the power steering pump resivour. I believe one ground connects to battery
srt4man
WV
The car is now running ,I got 6 new injectors and soldered my ecm grounds thanks for all the replys on helping me , its been a project car I have worked on for a while long while lol , got a few minor things to finish up on the car .
:thankyou:
crystizel
