help with trying to get outer tie rod off
Warren
New York, N.Y.
well I just bought a new outer tie rod and I cannot get the old 1 off I cannot get the nut o the inner rod to break free so I can back it off I cannot unscrew the old outer tie ro isoldit with pb blaster still no luck which way should the nut turn clockwise or counterclockwised.
kevinspann
Don't take my advice.
Richmond VA
You need to turn the nut clockwise (like you're "tightening" it) and the outer tie rod needs to be turned counterclockwise. Leave the tie rod bolted to the knuckle in order to break the nut loose.
Warren
New York, N.Y.
for 40 minutes I've been trying to break this thing loose with an adjustable crescent wrench by turning a clockwise and it still won't break loose I even tried vice grips
notbange
Love fiST
Sale Creek TN,formerly MA
If you're sitting looking at the car from the outside the jamnut will be turning clockwise. If you were underneath the car looking at the nut you will be turning it counterclockwise. Try heating it with a torch. Usually its easy to get the nut to break free from the outer tie rod, it can be quite difficult to get the jamnut to turn freely on the threads of the inner tierod.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Leverage! Double up your wrenches if you know what I mean. I had to get my angle grinder out and take off some of the nut and tie rod itself. :) Wouldn't move for me either.
Tierod
frosho
WOLFMAN
Tyngsboro, MA
Try heat? Somebody probably put red loctite on the jam nut. It comes with new outer tie rods sometimes, and I don't understand why. They think we will never need an alignment?
Warren
New York, N.Y.
I had to get ahold of a nut splitter to get mine off....it happens.
How do you use a nut splitter on the nut that's already on the tie rod? The nut splitters I've seen are a closed loop how would I get it pas th outertie rod end?
Warren
New York, N.Y.
Well I finally got that nut loose by fitting a pipe over a pair of vice grips and it finlly broke loose. Thanks for all of the advice
