Terrorizer
SHO or ****
Last night I was driving from one side of town to the other, and I stopped at a light, when the light turned green I shifted from neutral into first but It felt like I was in a higher gear and the engine was about to stall. I also noticed that the shifter felt really loose and wobbly. On my way home on the freeway I tried to shift into 5th gear but I felt like I was in 3rd gear and again the shifter felt loose and kind of flopped over into where 3rd is so I left it in 4th all the way home. I also noticed if I shift into second then first it will sometimes go into first gear.
I'm thinking it may be something related to the shifter cable, any ideas guys? Is this ok to drive with? I have work this weak and don't really have time to fiddle with it until the weekend.
My car is a 1990 mtx
Yep. I have also done this. When you have a buddy in the pass seat freaking out while your under the car, it's even funnier. Then you hop back in looking like a mad genius. "you fixed, it? Wow." ...is the common response. Then you humbly say, "Yeah, but it'll probably happen again."
