Terrorizer
SHO or ****
I used wire. No pictures, but basically criss-crossed around the joint as much as possible while still allowing the joint to move.
I believe the clip is a Mopar part. Then again, I might be thinking of a fix for the for-aft cable.
Did you go around the close part of the bracket directly behind the ball joint, or did you go all the way around the bracket?
