Does this SHO sit too low in the rear?
Airborne
After putting on '95 knuckles and new front struts I took my '89 in for alignment. Big O said they were able to get the front perfect but the rear was at 2.25 percent and sitting too low. They recommended that I put on new rear springs and eccentric bushings, bring it back within 30 days and they would re-align for free. I like how it sits and rides, so I put on eccentric bushings and brought it back. They were able to get the rear to 1.5 percent, which I can live with. Big O said the alignment is closer, but still sits too low, bring it back with new springs and they will do it again. I asked if I put on another set of eccentric bushings or adjustable rods, would they still do it for free? They were being cool and said sure. My question is do you guys think this car sits too low? or too low in the rear?
P1240089
P1240090 1
P1240091
Ishodu
If there not lowering springs, they are sagged. You would be better off getting some adjustable control arms to get it aligned the way you want rather than using the bushings.
GM GTP arms fit the SHO with a sleeve kit from SHONUT. If you search it I am sure you will find lots of info on this.
intimdatr
Got Cams?
Jefferson City, Missouri
Good lookin' car youve got there!
The rear does look like it sit pretty stickin' low! I Personally would get new Struts and Springs to increase the handling of the car and once the new setup had broken it should ride just as well if not better! But its just my two cents.
Airborne
ok, so I should get new springs, and while I am in there I will put on struts. I am looking for stock height and ride. Which ones? Front height looks ok? Will the front be low now compared to the new rear springs?
kevinspann
Don't take my advice.
Richmond VA
I don't think the front would be too low. Monroe sensatrac struts, and maybe Moog cargo coils, with a dead coil or so removed to make it sit a little lower.
How many miles on the springs?
DJSHO91
Durham, NC
It's actually setting fairly normal for a Gen1 SHO. Here's a photo of my 91' with 16" Alloys:
Most of the sinking look is actually a simple illusion because the rear wheel opening is smaller(and less flared) than the front. :salute:
kevinspann
Richmond VA
I *think* if you can find or borrow a factory manual, it has ride height measurements in it, to measure from hard points on the body down to the ground. I have one for a 92, and it might be the same.
Edit - this section was actually for measuring the unibody, not ride height, so may not be of any value.
I assume you are meaning 2.25 degrees and 1.50 degrees, not percent. 1.5 degrees is perfectly fine for a street SHO as long as they have enough toe-in.
I think the rear is perfect height, you just should lower the front an inch.
There will be no performance improvement with new springs that raise it up, because the car will sit higher it will not handle quite as well. the spring rate of the springs doesn't change, they just take a 'set' so the free length is shorter and therefore the are slightly shorter when compressed.
intimdatr
Got Cams?
LOL. I was being sorta very vague. I meant to imply that fresh struts and cut springs the handling could be improved because the back end doesnt bounce like the wind when in a rough conner.
Not to derail the thread!
LOUDSHO92
Rancho Cucamonga, CA
Typically you don't need anything extra to adjust the rear so you do have something going on. The Ingalls adjustable control arms will probably get you into range: SHO Source
Moog springs are good stock replacements: SHO Source
They pair well with Monroe struts: SHO Source
You will need strut mounts as well: SHO Source
You can also get quick struts: SHO Source
kevinspann
Richmond VA
Quick struts will definitely raise the rear. My gen 2 sat pretty high on them.
dohcsable
Gold Calipers>*
Indiana
my 92 sits kinda the same way, just depends if I want to bother with the new moogs that came with it....lol
it sags much worse if/when you take a stab at the secondaries tho
