Hope I don't jam too much into this thread. I'm trying to incorporate as much from other posts relating to these topics as I can, for future searchers.
1) Been getting Low Coolant light recently, and topping off every few days. Then I realized that the level was staying at a low point but yet not leaking anymore, thus the motor never got hot. Still, I needed to resolve the leak. Took it to a shop to have it pressure tested and found a leak on the outboard side. I contend that it was caused by a heavy jarring when I hit a speed bump too fast (hey, it was unpainted and it was raining at the time!) but the mechanic said no way. Hmmm, a 13 year old plastic tank, in Florida, whatever . . . so they want me to pay over $150 to put in a new reservoir. I read an older link about an "upgraded" one, Dorman? Said it was from autozone, but I could find nothing from autozone for 98 SHO coolant reservoirs. Then I read that they use the same part as the Duratecs. The mechanic said the part was SHO-specific. Nice. So, can somebody point me in the right direction where I can pick up a new coolant reservoir? Thanks!
2) Steering's been REAL tight, squeaky, jittery, whiney, etc. from a start for the past couple months. After a few minutes of driving and turning, it becomes much smoother. Same shop tonight, the guy says the pump is leaking. The problem I have with that is that I haven't put new fluid in it in years
, and the oil changes haven't reported low levels. I did the front brakes recently and when the car was up with tires off, I started the motor (to pump pistons back to engage pads). I then turned the wheels left and right and they moved smooth as silk. So if the pump's leaking, how is there still fluid after all this time and why does the steering smooth out after warm-up? (I think I know --> needs fluid changed). Does anybody disagree with my assessment? Could these symptoms indicate a leaking pump? I read up on v8sho.com where to disconnect for draining the PS fluid, but not completely sure about which hoses (http://www.v8sho.com/SHO/psflush.htm). Murdock says driver's side, but Nimz says passenger side. Hmmm . . . Here's a diagram:
Does anybody have pics of this? I changed O2 sensors a few months ago and could have done this since I had the radiator splash shield down. Just a matter of fighting all those little screws. I wasn't being proactive at the time I guess.
Sorry for the rant!
:thankyou:
Sorry for the rant!
:thankyou:
