I dont know where to post this
shoff22
missouri
I bought a sho from a guy that got it from his friend and i cant tell if something is done to it but it seems faster than it should be and the lisens plate on it was an illinois lisens plate that said shoqik 2 i was wanting to know it anyone knew who used to own it and if the did what is done to it if anything is done
shoff22
missouri
Its a red gen 2 mtx with a sunroof and it had tinted windows but some of the tint was riped off it was wrecked in the front and the bumper hood and passengers fender was replaced with green ones and painted red
haydenm315
Reisterstown, MD.
One of the first things usually done to these cars for performance is replacing the restrictive y-pipe. The factory pipe has a restrictive point where the pipe meets the 2nd catalytic converter. See this pic.
If the car doesn't hit the rev limiter around 7300RPMS, the car probably has a computer modification. The motors in these cars are known for their high revs. 8000RPMS is usually what the chip will get you. If you're spinning up to 8k, the accessory pulleys should be replaced. One reason for the 7300RPM rev limiter is to protect the accesories from spinning too fast. The pulleys are probably polished aluminum and easy to spot.
shoff22
missouri
syriac honesks
it has tyhe stock y pipe and no pulleys but me and my fdriend think it might have cams how can i tell if it has cams or not
AREA 91
Area 91
Do rod shifters come stock in the mtx shos
89-early 91 are cable shifters
The rod shifter was brought into production mid year in 1991, and ran through the end of production in 1995.
jayro
Auburn, In
Camms for the SHO are reground stock ones that use lash caps to make up the difference. With out tearing it apart to inspect things it would be difficult to tell. If everything else appears stock I would imagine the camms are too. Replacing them is pretty far from a first mod.
