speedysprocket
sho runner
Inspired by another member here, I decided to take an old mount and make it a little stronger. I removed the limiting pin and drilled the mount in four locations, on the ribs. In an effort to limit NHV, I’m trying these rubber lined washers (stacked x2 on the base and x1 on top) and grade 8 hardware, 5/16”. Loctite will be used once I torque everything down. Let me know what you think! There is always room for improvement. These things seem to fail just as fast as you press the gas pedal down or chirp the tyres.
Basic Design:
Inside view:
NVH "eliminators"
Bye bye limiting bracket and limiting pin:
Still brainstorming for options on keep in the washers intact because of the high pressure and torque. Maybe a little JB weld around them to form a retainer or shroud
Basic Design:
Inside view:
NVH "eliminators"
