sperold
Last to Know
90 SHO.
Up and down was failing when operated from drivers door master switch. Noticed it worked ok when drivers door was fully open.
Took door panel off, seemed ok in the door. Looked at the can thing on the front of the door and noticed the wiring "scrunched up" when the door is opened. Thought that "scrunch" moved wires in the cabin area and wore off the coating, exposing the conductor metal.
Took the foot panel and the door-sil plastic parts off and rolled back the carpet to look at the wires, and they seemed ok.
I knew the wire colours from looking at the door switch, so I could identify the wires in the harness in the door-sil area. Problem was, both passenger windows have the same wire colours (red /black, yellow /black), so I had to run the window with the door open to isolate the 2 wires that run the front door (with a stab the wire and a light turns on thing).
Put tags on wires to avoid doing this again in the future and while doing that, tugging on the wire resulted in the window not working with the door open.
Tugged a little more and the wire came out of the pin cushion on the bottom of that can-thing on the door front.
Serious action required.
Took the door off, and put it on a stack of 3 tires to look at the bottom of the can, to try and put the wire connector back in the pin cushion. The wires are all still connecting the door to the car at this point.
There were so many blank holes in the door can, that I could not tell where it came from.
But when I ran power to my loose wire, the window went up, so I knew that wire was intact.
I ran a new wire to my door master switch and exited the door just under that can-thing, as there is a space there.
I attached the new wire to my loose wire (outside the can, and outside the rubber boot) and all things worked well.
Reinstalled the door with the help of some jack stands and a small hydraulic floor jack, and fiddled around until it fit well.
Not a pretty fix, as you can see the rogue wire where it enters the rubber boot at the bottom of the door can, but the results are good.
Another thing I learned was that can thing on the door front, I always thought it rotated to make the wires stress-free, but it does not, it is no better that the rubber boots on all the other cars.
Fixing the one wire made both the up and down function properly, I was expecting to have to fix 2 wires, but I was pleasantly surprised.
