sho help!!!!! missing coolant
ThatShoGuy
michigan
ok a buddy of mine has a 97 sho
he keeps losing coolant.the car over heats on long drives,can idle in drive way for 20-30min and not over heat.. he dont see any coolant leaks..
he has changed the water pump,why im not sure. he also thinks it has a bad head gasket. which i told him that is uncommon on these cars but anything is possible..
i think i might have a leak at the T near the lower intake or something.. i havnt seen the car yet so this is just what i was told over the phone..
thanks for any help!
Is there a bunch of smoke coming out the exhaust? A broken T or old hose could do it. Also a leaky radiator especially at the endtanks is not uncommon. I had a few hoses and T's go bad. Have extra T's on hand if you start disconnecting the hoses. They are likely very brittle and tend to break when you try and pull the hoses off.
LJRuddy
Pop lock n drop
Poaceae fields
There's a short 2" (i think?) coolant hose that is only about 2 inches long that runs underneath the throttle body. Mine had a small pin ***** in it last summer and it took me forever to locate where my coolant was going.
ThatShoGuy
michigan
thanks guys i dont think i has a head gasket prob but you never know.. like i said havnt seen the car yet so i assume they dont see a leak..
i also thought of the coolant expansion tank also..
Brydakidz
It's SHO Time
New Jersey
It very well could be that the expansion coolant tank warped, or the cap warped. Same situation happened to me. It's pretty easy to replace.
ThatShoGuy
michigan
i mine as well be a sho expert lol .... i have put 3 motors and working on taking the trans out for the 3rd time. and have owed it since 03 or so.. done my share of work on it...
that was the same thing wrong with mine as well has being cracked on the bottom...
i think its something stupid that most guys over look..
