Hey all,
I'm hoping to clear up some misunderstandings I'm getting while researching for a boost project.
Often, people I see quote "max psi" as the variable that controls when your engine throws a piston at the car in front of you. Or towards your teeth. But is it PSI or horsepower? PSI is just the amount of air pressure over ambient you're feeding your engine, but not flow. Flow is where horsepower comes from. As an example, a supercharger making 7 psi on a stock block is taken off and the whole intake is ported, polished and optimized. The same supercharger goes back on, and only makes 5 psi with the same pulley, because the engine flows more without it and is eating the boost faster than the SC can make it.
So in that case, say the engine is known to vent headgaskets at 7.1 psi, so everybody sticks to 7. After the mods, let's pretend it's making the exact same horsepower as before but with 5 psi. Could you then increase boost safely back to 7 psi to make more power? From what I can tell, more fuel & air will do wonders for cylinder pressures.
Now to get car-specific, I remember seeing SC kits for the gen III from somebody, offering a 6 or 8 psi kit, and a 16 psi kit. It's been said before that nobody knows how far to take the stock V8 block, but I'm wondering if something blew up while designing the 16 psi kit, or if they just replaced pistons out of principle. If I get my project rolling (and I'm not making any promises) I'd be happy with 350-400 at the crank, but we all know I'll only stay happy for a few months before I set my eyes on 500+. It would be nice to know the limitations of these engines ahead of time, so I can plan accordingly.
