Radiator fan - unobtanium
SaltyDog
San Diego, CA
Looking for some sage advice. I have a '95 MTX. The radiator fan motor ate itself last week - ruined the fan also, melted it to the motor spindle.
I've surfed the forums and read where Motorcraft RF18 replacement shroud assembly would work...it didn't. Shrouds are different sizes, fan is similar but slightly smaller than stock. The motor will bolt into the old shroud, but electrical connections are different.
I am able to order a fan motor, but not the fan - have to order the entire shroud assembly, but as stated, it doesn't fit.
Ugh.
Anyone know where to find/order a replacement?
Should I go with an entirely different fan set up? (if so, suggestions?)
Shroud = F4DH 8C607-BB
(F4DH-8146-CA stamped on the inside of the shroud)
Motor = F4DH 8K621-BA
Fan = F1DE 8600-BA
I noted after the fact that the Motorcraft RF18 matches a shroud ending in -AA vice -BB.
Standing by for comments/suggestions/ridicule.
Thanks in advance
LOUDSHO92
Rancho Cucamonga, CA
We can get you a good used one at SHO Source. Just send us an email and we will get things going.
kevinspann
Don't take my advice.
Richmond VA
There is a '95 MTX at a junkyard here in Richmond that appeared to have a good fan - it was a blown diff car.
sperold
Last to Know
The motors from the V6 Tempos are the same, and there may be more of them at the yards.
SaltyDog
San Diego, CA
Thanks for the tip - I haven't been able to cross-ref it to anything else. I figured there really SHOULD be something else that uses the same parts.....
But the real question: Is the fan the same?
I can get the right motor @ Advance or AutoZone, but I can't get just the fan.
K-Dawg
Treasure Coast, FL
There was something in the latest Car Craft about using Taurus and Mark VIII radiator fans in hot rods. I think it said where you can get new ones.
LOUDSHO92
I haven't seen it yet.
SaltyDog
San Diego, CA
WIN!
Kevin - thanks for the tip. Fan shroud assembly acquired and installed. I'm back on the road. I owe you a cold beverage.
Looking at it...I don't see a way to replace the motor. It looks like the fan is perma-pressed onto the fan spindle. Hope I don't have to do this again...
kevinspann
Richmond VA
Good to hear! We'll have to try to get together some time. I woulda met you out there, but I had to work.
Rubix
I couldve come too, that junkyard is under 3 miles from my house as the crow flies! Glad it's fixed Saltydude
itwonder
VA
WIN!
Unless they changed the design from '92 (don't think they did), the plastic fan will come off of the motor shaft. Then you can disassemble the motor, replace the four brushes, and it will be good to go.
