Radiator Cooling Fan Assy.
klrsmith
Central FL
I have noticed lately that after I shutoff my 14 Ecoboost PI, as the fans shutdown a few seconds after the engine is turned off, I hear them squeaking as they come to a stop.
How hard is it to replace the fan assembly - and does it require that I remove all the front end stuff (bumper cover, radiator, coolers, etc). Or is it an easy drop in type replacement?
Can I assume this is the correct ford part number for said assembly?
DG1Z-8C607-E Fan & Motor
Fan Assembly
3.5 LITER W/ TURBO, W/ OIL COOLER
krewat
Long Island
Does the PI Ecoboost have only one fan as indicated in that link? Am I crazy, or did I see two motors in my 2018 PP?
ON EDIT: I did a search on that part number, and other sites show two fans...
klrsmith
Central FL
Johnbigdog
michigain
You should be able to remove the fan without the removal of the radiator as when I flushed my cooling system (which included removal of the radiator) the fans came out first.
Aslo, the new ford fan should not squeak like the old one. I think it was a problem with the brushes making noise.
klrsmith
Central FL
Cool guys thanks for the info - sounds like I don't need to worry about pulling the actual radiator out or pulling off that clip on bumper cover and associated PITA stuff - I have the part ordered. I'll let you know how it turns out.
313tiger
