94 mtx sho no spark
green94mtx
I have a 94 MTX with no spark.. All fuses are good. Tach works when cranking, so crank sensor should be fine. Cam sensor has power. Has good fuel delivery. And a new DIS Ignition module didnt do anything. Everything is good but still NO SPARK... Might be the Coil Pack after all. And if it's not the coil pack, then what? Any ideas?
classic symptoms of bad crank sensor.
pull the codes as suggested rather than guessing.
