Showgun
Canuck SHO
That sounds hopeful Blaine.....Let's hope they can make repairs for you in an orderly fashion.
You got the car back or did they lend you one?
PROGRESS!!!!
So I got a call today from the service manager with some "news" on my situation. The data that he sent up to Ford was analyzed and they noticed that just preceding the opening of the wastegate one of the knock sensors was reading about 500 ticks more than the other knock sensors. What does the computer do when it detects excessive knock? It cuts power to the engine so that it doesn't go BOOOOOM!!!! Interesting. So, the engineer told the service manager to inspect for a chaffed wire. If one could not be found he was to replace the knock sensor giving the excessive readings.
So I immediately headed over to the dealership so we could start looking. After giving the engine 10-15 minutes to cool we started digging. And what did we find? If you said a chaffed wire then give yourself a cookie. The wires go to one of the knock sensors below the intake manifold. You can see that wires that come up into a connecter and were not wrapped in any electrical tape or in any type of protective plastic shrouding and it was resting right on a 90 degree edge on the engine.
This would explain how my issue started as a once and a while issue and degraded into a full-time issue as the chaffing progressed and got worse.
First remove the engine cover just to make sure it's out of the way so you can get a good look from all angles. Look down between the 2 intake pipes.
Go Digging - Big Picture
We saw a connector with wires that were not wrapped in any extra electrical tape or plastic shrouding.
Chaff - Big Picture
From this angle you can better see the wires resting on the engine.
Chaff - Big Picture
The chaffing is on the sensor side of the connector which means that they will have to replace the knock sensor. In the meantime we have put a piece of foam insulation on the engine where the wires rest to prevent it from further chaffing and giving false knock readings. I must say that performance is starting to come back. Since we didn't reset the KAM memory, it is taking some time for new values/averages that the PCM uses to run the engine are being used and faded out as new values are factored in and averaged. Power is coming back, the erratic RPM's are fading, the wastegate is bleeding off less and less air with every mile I go.
The new knock sensor should be in Tuesday but depending on what time it comes in I may not get my car back in there till Wednesday. I will have them reset the KAM and also check to see if there are any more software updates available to get me all up to date on everything.
I'll report back Sunday/Monday as I put more miles on my car to let you know if the condition continues to get better as well as what it's like when I get the new sensor in. I will be taking a road trip tomorrow so I will get to get a good like to see if my HWY MPG's are improving. With this issue I was only getting 21 - 22 MPG tops on the HWY when I used to get 26-27 (while driving 80MPH - 90MPH).
Now I would suggest that all of you go out and check for those wires. If they are exposed I would inspect them for any chaffing and then I would recommend wrapping them up in some electrical tape or other means of protection.
I just got back from my weekend trip and I must say that I am running 90%-95% of where I should be. My HWY gas mileage up (about 210 miles) was 26.2 MPG. This is much better than the 21.5 MPG that I was getting before with all the problems. My MPG on the way back was 26.8 MPG. This was all averaging about 77 MPH.
Power has also returned to near full strength. I should be all fixed up on Wednesday with the replacement of that knock sensor with chaffed wire and a resetting of the KAM.
Does the problem still clear up after the KAM is cleared? seems like they should be able to datalog or read the stored parameters to see which variable is being affected. i.e. - A/F is going overly rich due to a faulty O2 sensor or chaffed wire?...
I was close. No cigar, but I'll take that cookie.
Mine were touching , chaffed a bit and with the hot engine, I'm sure they can probably short out. Tapped them back, reset the KAM (battery disconnect) and I think the engine came back to life! So far so good - excellent post!
Its a 2010 (early build 7/09) and had the similar issues that Blaine had - air rush when accelerating and feeling more like a 150 hp car. Tapped the wires out of the way and all 365 are back. That area also has the thermostat housing around there so gets very hot, even after the car has been off for hours.
