vortex2450
Buying Parts...
Hey, I swapped in a 3.2l little more than a month ago, when I did the swap I replaced both upstream 02 sensors, 3 weeks after that my gas mileage was lacking, so I pulled both sensors and the rear sensor rattled when I lightly shook it... So that's o2 sensor #2 for the rear bank after the swap. NOw i'm throwing the 172 code again I the car seems to lack some power so I suspect the rear sensor went AGAIN! At $40 a pop these aren't cheap.... I haven't checked it out yet but what could be doing this?
Also, it's notable the before the swap the rear 02 sensor on the car failed and threw a 172..... It also rattled...
I don't know, I suspect since it's a different engine maybe my wiring is ***** and somehow physically breaking the sensors?
Or maybe my y-pipe is at fault?? It's not a 3rd part pipe but looks custom welded, the rear outlet isn't equal length, it just comes straight down about 8" thens hits a shallow 90 degree bend into the collector... the 02 sensor bung is about 3-1/2" from the exhaust manifold...
I'm slightly irritated because I know i'm loosing mileage and power but I don't wanna fork out another $40 for a sensor before I fix the issue...
-Josh
Also, if it helps, the engine makes a little noise in the valvetrain, it seems to comes from the rear bank, this may be a related or not, but at least I could mention it
-Josh
Unless anyone else has any ideas...
