100 shot.
jayro
Auburn, In
I was being sarcastic, as I have been running a 100 SHOt for years!
:swing:
I was thinking about that. You say you are running a stock tune on yours, so does that mean you are running 3.2 injectors? I thought they were only good up to about 300chp? Just kinda curious since I have been thinking about adding the purple pill of power.:evilgrin:
auto.guru
Village Idiot
Neenah WI
yeah i was wondering the same thing....
did you just "bolt on" a 100 shot and were good to go?
have to change the injectors to a 3.2L?
im about to do this...
AREA 91
Area 91
Start out with the small jets first, and keep tabs on the ignition timing and A/F ratio.
You can always go bigger, but changing pistons is no fun!
3.0 injectors are pink and are rated at 23.7 Lbs
3.2 injectors are purple and are rated at 24.4 Lbs
There is not a big difference between the two.
Might be 10 hp difference.
I have lots of mods on my car, so it isn't a fair comparison to the average sho out there.
FYI My fuel system consists of cleaned/balanced 3.2 injectors, big fuel pump, and SHO NUT aftermarket FPR.
